Page 3 of 3 FirstFirst 123
Results 31 to 39 of 39
Thread: 1JZ-GTE in to an IS200
    Jun 2008
    Brighton
    Default Re: 1JZ-GTE in to an IS200
    yeah think that might be a good idea, think i'll head to the scrappys lol
    If it becomes troublesome with the factory IS stuff, I'd be ripping the ABS gear out of another Toyota without a body computer, wiring & computer included, & installing that instead.
    Id be careful with doing that. The ABS is tuned for the particular model and it knows all the parameters (characteristics of that chassis altered by different options: weight and distribution, brakes, suspension) that can affect how the vehicle will behave. Yes, the fundamental 'prevent the wheel from locking up' is the same and the modulator will do its best regardless of what changes have been made to achieve this.
    Change one of those and you do have the potential to cause issues. I do say potential as i have seen many cars with brake upgrades with no percievable issues - but then again i havent seen these people take their cars to a race track.
    Any reason why you want to keep the ABS for a race car? Surely a decent driver would be able to perform better without it, and over here most regulations require that it be deactivated anyway. The only reason i would be using ABS is to obtain a factory wheelspeed sensor rather than having to graft one on. Id piss the rest of it off, some modules weight in the vicinity of 25kg (doubt that the IS would be that but thats a lot when it comes to a race car)
    The ABS is independent of the engine ECU (and the body ECU). On the autos the ABS supplies the speed signal to the cluster and engine ECU but it doesn't affect ABS operation.
    Replacing the ABS makes virtually no sense given it still works without any other ECU....
    There has to be a reasonable amount of adaptability built into the ABS as some of the biggest variables are the easiest to affect - eg brake pads and tyres.
    Mos.
    Jun 2008
    Brighton
    The only reason i want it is for rain, as we no it does that alot over here in the UK as it will be my first race season i would prefer to have the safety net of the ABS in wet conditions.
    Mos - so the IS200 has a complete seperate ECU aswell ? Any idea where this is located. The whole wiring loom is out of the car now so i will just need to find it and rewire.
    I cannot believe the amount of wiring in the car it is crazy. alot of weight as well. If worst comes to the worst i'll have to run without ABS and be super careful on those rainy days.
    The power steering controller ? Is that complete seperate as well or will this be linked to either the 1jz/1g engine ECU ?
    Thanks for the help guy really need it as you can tell
    Picking engine up next week yippppppy
    Quote Originally Posted by Mos
    Mos.
    Based on this, I would ignore my earlier suggestion.
    Jun 2008
    Brighton
    Well chaps here she is, been sitting in the garden for a litte while hence the rust.
    Its bloomin big and freckin heavy but i love her already
    The turbos have ZERO play in there like new its crazy. What do a pair of these go for price wise ? Thinking of going striaght to the big single instead of trying these out first less hassle.
    My new favorite picture is this
    Jun 2008
    Brighton
    Quote Originally Posted by oldeskewltoy
    Hmmm, whats the big deal here......... The US Lexus IS300 uses a 2JZ engine.
    PNC Part Number/Description PPC* Specifics
    12311 12311-46140
    Lexus OEM Engine Mounting Bracket Front No.1 RH 1 Manual Transmission Only $82.75
    available
    12315 12315-46120
    Lexus OEM Engine Mounting Bracket Front No.1 LH 1 Manual Transmission Only $94.61
    available
    12361 12361-46190
    Lexus OEM Engine Mounting Insulator Front 2 Manual Transmission Only $113.63
    In Stock
    12371 12371-46160
    Lexus OEM Engine Mounting Insulator Rear No.1 1 Manual Transmission Only $76.07
    In Stock
    12371 12371-46230
    Lexus OEM Engine Mounting Insulator Rear No.1 1 Manual Transmission Only $81.77
    available
    12381 12381-46070
    Lexus OEM Engine Mounting Stabilizer 2 Manual Transmission Only $16.72
    available
    12391 12391-46040
    Lexus OEM Engine Mounting Front Insulator Heat RH 1 Manual Transmission Only $15.26
    available
    http://www.sewellpartsonline.com/ass...l=207&year=166
    What is the "12371 Lexus OEM Engine Mounting Insulator Rear No.1 1 Manual Transmission Only " I dont see how these will fit on to the 12361's ?
    Any help would be good, from a quick look today im guessing all i need is the 12391, 12381, 12361 one of each for both sides. Is this right Mos ?
    Cheers Elliott
  8. #38
    Jun 2008
    Brighton
    Well this project is still going just slowly, funds are very low and parts taking a while to arrive.
    Just got some money so looking at getting a manifold.
    Been looking at cheap Ebay ones just wondering your thoughts on them.
    Has anyone bought any of ebay ? if so what are they like ?
    Been looking at this one
    http://cgi.ebay.com/ebaymotors/Toyot...Q5fAccessories
  9. #39
    Junior Member Grease Monkey Yojimbo's Avatar
    Nov 2007
    They are fine if you take the time to prepare them. They really need to be sectioned up, cleaned out and re welded. There will be a lot of welding slag and spatter inside ( that you cant see) that will release and go through your turbine at random times as they heat cycle for the rest of thier life. This has cost quite a few turbos amongst those who have used them, my first turbo included.
    Lexus IS200: 4 x Toyota Nationals - TOP TOYOTA
    [email protected] (400m)
    22.01@164mph (1000m)
    Built by ... JMR Race Engineering - Toyota Specialist
  1. 1JZ vs 7M alternator useful info and pics
    Last Post: 22-06-2009, 04:10 PM
  2. IS200 1JZ GTE in the for sale section..
    By IS1000 in forum Toymods Car Club Membership and Feedback
    Last Post: 04-05-2007, 08:31 AM
  3. 1jz vs 2jz heads
