Results 1 to 11 of 11
Thread: 4a into suzuki sierra
    wa
    Default 4a into suzuki sierra
    well i started up a little project ive been working on today , 4ac ( yes C ! ) into my sierra.
    it all started when i went to get a T50 box for the GTE that will reside there later and the guy had a 4ac bolted to it , i ended up getting both for $100 and it got me thinking ..... so after a few beers i decided that i would do it . the big thing with it is that there was to be almost no wiring, i just had to re route 5 wires and thats it. the other thing was that mounting it this time sets it up for the 4ag later on , making it SO much easier for me in the future.
    funny things :
    fuel lines hooked straight up no mods
    intake adapter bolted up no mods
    radiator hoses , FIT NO MODS hahah
    throttle cable fit no mods
    wiring needed no extensions, just stripped back the loom and re routed stuff.
    i have retained the standard sierra cable clutch setup but i have made my own bracket and arm setup to fit the T50.
    the mounts were SO easy all i did was drill into the existing mount block on the chassis drivers side and sink the 4a rwd mount straight onto that , and used a bit of 4mm flat plate on the passenger side . gearbox has some more flat plate to adapt to the chassis and thats it.
    gearbox needed a small jackshaft to fit up to the transfer case, using the sierra transfer flange and a T50 yoke. for those that dont know the sierra utilises a 'divorced' transfer case. being that the engine and gearbox are as one on a 'regular' style RWD and then the transfer case is separate.
    i spent a grand total of 26 hours (accumilated) and $160 to do the conversion including EVERYTHING . sold the standard motor and box for $200 hahaha what a winner. i think the engine really looks at home in the bay all hooked up.
    My Corolla ! - 4AGTE
    KP61 - 4AGE
    Default Re: 4a into suzuki sierra
    Good stuff. ive got a sierra aswell and was thinking of putting a 4ac in for a bit more grunt
    vic
    I did this a few years ago , except i got the front tailshaft lengthend and the rear shortened , and made up custom transfer mounts . I also had custom jack shaft made up with replacable uni,s at the T50 end also the longer the jack shaft the less vibration you end up with .
    Ive still got all the gear if anyones keen to buy it .
    Dave
    wonder what happened to this guy http://toymods.net/forums/showthread.php?t=1176
    looks liek a nice fit, and a bit better than the suki motor
    wa
    Quote Originally Posted by cambelt1
    Dave
    i moved my transfer box upwards 50mm (almost against the body now) and back about 20mm , just so much that i could get everything to fit comfortably and for the jackshaft to be as close to straight as i could get it .
    im pretty sure if you put the gear youve got up on outerlimits 4x4 forum you would have no trouble selling it
    URL (suzuki section) http://www.outerlimits4x4.com/viewforum7-0-30.php
    KP61 - 4AGE
    Convictania
    man the sierra 1300 motor is fucken pathetic, good work on the upgrade.
    Your mum loves my Grease Monkey TasCressida's Avatar
    Apr 2008
    tasmania
    nice work mate ...
    Turbo48 on here from tassie also put a 4AGE 88kw in one a few years back now ...was a mean little machine.
    4AC will def haul over the 1300.
    JZX90 Lovin'
    wa
    so i was jabbering with my housemate over how much of a bitsa this is and i thought people may find it funny.
    yoke: AE86 JDM
    gearbox : AE71
    bellhousing AE86 JDM
    motor AE71
    crank pulley AW11 n/a
    water pump AE92
    water pump pulley AW11gze
    water pump housing AW11gze
    alternator AE101 gze
    remote thermostat from an AE82
    engine mounts AE71
    coil AW11gze
    random radiator hoses
    starter motor T18 (apparently)
    no two parts came from the same donor , its amazing what you can put together from random stuff laying around ! haha ......
    KP61 - 4AGE
    Apr 2008
    tasmania
    rep for random parts car lol ...cross breeding ...but at aleast u used near every toyota corolla part available lol
    JZX90 Lovin'
    ToyotaCarClub.net Domestic Engineer Starfire's Avatar
    Nice work. +rep.
    Nice one Ads ,was wondering how long you could stand the mighty G13 suzuki engine.
  1. 4agte suzuki sierra!
    By 4agtezook in forum Tech and Conversions
    Last Post: 07-02-2007, 10:48 AM
  2. 4A-GE to Suzuki Sierra
    By mullett in forum Tech and Conversions
    Last Post: 30-05-2006, 09:45 PM
