Results 1 to 15 of 28
Thread: 20 valve pushing oil from valve cover breather after rebuild
    Junior Member 1st year Apprentice boon280's Avatar
    Apr 2007
    S.A
    Default 20 valve pushing oil from valve cover breather after rebuild
    I have just put a set of rings and bearings in my silvertop and now it is breathing oil from the valve cover under high revs and load.
    Is there anything that i could look for before pulling the engine apart?
    I think that maybe the rings did not bed in properly.
    The engine is being used for offroad racing so it is under high revs and load constantly.
    any ideas would be appreciated.
    Low rep 1st year Apprentice
    Apr 2007
    tasmania
    Default Re: 20 valve pushing oil from valve cover breather after rebuild
    My guess is your block and head and under pressure and the only thing that i guess can cause that is air getting past the piston rings, or your valves maybe. unless your running some sort of forced induction.....
    Apr 2007
    S.A
    no forced induction all standard engine and ecu
    Apr 2007
    tasmania
    Test your compression let me know your figures..
    leakdown and compression test first and formost.
    Apr 2007
    S.A
    ok will try and do tomorrow night
    Apr 2007
    tasmania
    excellent let me know what happens i need rep points. hehehehe
    Jun 2008
    Check that the engine breather tube (most likely going from the rocker cover to somewhere into the inlet manifold) is not blocked.
    and not just the tube but the PCV (positive crankcase breather) its basically a 1-way valve for blowby
    Melbourne Victoria
    did you dunny brush the bores before you put the new rings in with kero ,or just put said rings in and hope they might bed in ,if bore is glazed your out of luck ,pull head off and strip bottom end and deglaze bores and then put the same rings back in
    Apr 2007
    S.A
    did a compression test tonight and have pressure readings from 200 to 220 psi .is this too high? as I fitted a non genuine head gasket that is thinner than the standard one, seems to have excessive blow by on number 4. block was cleaned thoroughly before re-assembling.
    Melbourne Victoria
    was it rehoned with a dunny brush thou
    Apr 2007
    S.A
    yes it was honed with a "dunny brush" (sorry I just got what you meant)
    Jun 2008
    Excessive blowby on one cylinder might mean a broken ring. Did you use a ring compressor?
    Apr 2007
    S.A
    yes a ring compressor was used, the motor was assembled by a good friend of mine who is a qualified mechanic and has done many engine rebuilds.
  1. 4AG cam cover breather
    By Valkyrie in forum Tech and Conversions
    Last Post: 05-12-2006, 04:42 AM
  2. Quick Q - 2JZ / 1JZ Valve Cover Gasket
    By AndyTTR in forum Tech and Conversions
    Last Post: 30-09-2006, 12:10 PM
