Results 1 to 2 of 2
Thread: 1ggze Engine Fault
    Junior Member
    Sep 2007
    Default 1ggze Engine Fault
    Hi guys,
    Can anyone help me out, I have a 1GGZE installed in a toyota bundera and the engine fault light is coming on.
    After investigating further, the fault that is coming up is a "Vehicle speed sensor".
    Can anyone tell me what maybe causing this and how I can fix it and any possible diagrams to fix it, I think it has to do with the wires on the loom to the auto, but not sure. I have a 5 speed hook up.
    Thanks
    Bundy.
    Default Re: 1ggze Engine Fault
    Wire up the 4 pulse per rev output from the dash (goes to things like the cruise control) to the ecu. Problem will go away.
    But you'll be limited to 180kph.
    If the Bundy's come with an electronically controlled auto then chances are the wire is already near the ecu.
    If its not there you'll have to find the wire at the dash end.
    The colour has changed over the years, some of the early ones are LW, some of the newer ones are K
  1. Sams MA61 7MGTE Conversion Guide
    Last Post: 08-07-2015, 12:12 AM
  2. Toyota R Engine History
  3. 4age 20v Silvertop - Check engine light?
    By Macross in forum Tech and Conversions
    Last Post: 29-09-2010, 09:45 AM
  4. MA70 --> JZA70 Conversion
  5. Turbos 101
    Last Post: 24-01-2007, 08:23 PM
