I'm going to make it a little more complex than that...
Find the wire that goes to the 1JZ temp sensor. This can be done using a multimeter, put one end of the multimeter at the 1jz temp sensor wire [Unplugged], and then use the other end of the multimeter to find that wire inside the cabin on the ECU loom. That way if there is more than one yellow wire with green strip you'll have no issues
The MA61 body side should be a yellow-green wire too (you can always trace that back to the dash).
