Results 1 to 5 of 5
Thread: 1G-GTE to SA63 Celica Conversion
    Mar 2008
    Default 1G-GTE to SA63 Celica Conversion
    I've searched and searched and searched some more, Fail every time. Can anyone tell me in short what's required to do this conversion. I keep reading it's easy but no one seems to say what's required. How much actual fabrication is involved? Just the engine mounts or what?
    Trav
    SA63 Driver 1st year Apprentice red_63's Avatar
    Default Re: 1G-GTE to SA63 Celica Conversion
    You can either do two things do what timottaway did when he put his 1g in
    http://www.toymods.net/forums/showth...?t=6312&page=2
    Which involved bashing the firewall in alot so you can still use the standard sway bar, i think i have the same engine and gearbox mounts he used for his conversion lying around. Or you can modify your crossmember and fab up some engine and gearbox mounts, might either need to modify sump to clear sway bar or get a custom sway bar made, you'll need to shorten the tail shaft. Thats the main stuff i can think of at the moment.
    I didn't do the conversion myself on my car (cause i was to lazy), but what the did was modify the crossmember used the alloy engine mount to the engine and used 7m mounts to the crossmember and made a new gearbox mount. If you need pics of what they did just let me know and i'll take a few.
    Junior Member
    Is there any more info on this conversion somewhere??? Just want to know the basics of what needs to be bashed, removed, fabricated etc. for the 1G-GTE to fit.
    Also, can I use the W55 that's already in the SA63, and just bolt up a W58 bellhousing? Will that work?
    Nader.
    Quote Originally Posted by STi GUi
    Yes you can.
    Jan 2009
    tasmania
    Im doing the same thing soon, just gettin everything i need before i start.
  1. 22R -> 4A-GE Celica conversion
    By annoyingrob in forum Engine & Driveline Conversions
    Last Post: 25-09-2007, 09:38 PM
  2. MA70 --> JZA70 Conversion
  3. SA63 Celica question
    By WWeD in forum Tech and Conversions
    Last Post: 31-03-2007, 01:00 PM
  4. (TA22) 2T - 2TGEU conversion (now with pics)
    Last Post: 13-11-2006, 08:52 AM
  5. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
