Results 1 to 5 of 5
Thread: Mx83 1JZ Engine mount measurements
    Junior Member Grease Monkey slydin-cressy-style's Avatar
    Default Mx83 1JZ Engine mount measurements
    Hi guys
    I have a Mx83 with a 1JZ and am after the dimensions for the engine mounts
    Can someone see if:
    - the total height of the mount is 78~80mm and;
    - the location of the mounting bolts are in the center
    Any info is great
    Josh
    SUPPORTING AUSTRALIAN PERFORMANCE PRODUCTS...
    TURBOSMART MICROTECH JUST ALLOY RADIATORS
    THANKS TO:
    - ALL TRANSMISSIONS - IMPORT AUTO PARTS
    - P.I.T.S - PLATNIUM AUTO CARE
    Default Re: Mx83 1JZ Engine mount measurements
    my mounts have centered bolts, but i am using noltec ones:
    Quote Originally Posted by PlacentaJuan
    These would suit 1JZ also ??
    Did you notice the difference?
    Did you get alot more vibration through the chassis?
    THANKS TO:
    Stupid crappy $300 Noltec things.
    See here for a better method: http://forums.toyotacressida.net/for...ad.php?t=51996
    yea they are bolted up to jzx81 engine brackets so they should fit a 1j the same.
    after having cressida(7m),chaser (1jz) and aristo (2jz) engine mounts all broken in half, i would be very hesitant to go back to stock rubber mounts.
    those supora ones dont look too bad but they are still rubber though?
    mind you, i would rather replace some toyota engine mounts every few years than give my money and time to noltec again.
    Last Post: 12-07-2019, 05:11 PM
  2. Sams MA61 7MGTE Conversion Guide
    Last Post: 07-07-2015, 11:12 PM
  3. MA70 --> JZA70 Conversion
  4. SV21 Engine Mount Query
    By ajh in forum Tech and Conversions
    Last Post: 30-10-2006, 08:20 PM
