Well, just a small update today. Not much has been happenin becuase of work like usual.
I did manage to clean the block out, but i still have to cement in the oil dipstick tube into the block. I've also managed to mount the complete oil dipstick tube onto the powersteering reservoir as it would have been like from factory. All it needed was a little bending to take out some of the 'bend' so the hole on the bracket on the dipstick tube lined up with the bolt hole on the side of the resivour. Sounds confusing hey... I'll take some pictures on monday and post them up.
This is how the dipstick tube lines up against the PS Resivoir before straightening the tube. You can see how the hole in the bracket on the dipstick tube dosnt line up with the hole on the side of the PS resivoir.
So after a little straightening, the 2 holes line up perfectly. You've just got to be patient and bend a little, then line up, bend a little, etc. Till its spot on.
You have to file/drill out the hole on the dipstick tube just a little bit so the 12mm bolt, that mounted in the hole next to the PS resivoir, can fit through it. And thats it with the 12mm bolt in place, just as before. I havn't tried fitting everything else down on the block yet with the oil dipstick, e.g. the Oil adapter + Relocation fitting and the PS Pump to Engine Mount bracket. I'll test fit all these soon.
Here, you can just see the top of the oil dipstick tube with the (accordian pipe?) front pipe on the turbo. The oil dipstick tube touches the accordian pipe but dosnt press on it and its not a concern.
Also mounted the ‘power steering pump to block’ bracket. That required some bending and grinding to fit as well. Its all by feel, just bend it a little, test fit, bend some more, test fit, etc. Until it fits perfectly.
I've also taken off the turbo supports to give them a coat of paint. They were looking very rusty and thought why not. It'll improve the look of the engine a little and should stop some of that rust.
I acquired my new W55 on Thursday and spend the day cleaning it up and started to put the W to M bellhousing on. But the threads inside the gb were dirty and it was getting late so i called it a night. So the bellhousing will go on, on Monday. So at the moment i have a very clean looking gearbox sitting in my garage at the moment awaiting a bellhousing.
I've also made some more progress on my MA70 radiator support bracket. It's pretty simple to make. All you need is a 3mm Aluminium (or steel) 90 degree piece of metal, then drill the holes for the radiator mounts and cut off excess metal and drill mounting holes. I'll post up measurements and specifications at a later date but heres some pictures on how it’s going.
In this picture where the 2 arrows are, there were 2 little 'humps' in the chassis. I flatened them down so they were flat with the rest of the chassis so the bracket im making wouldn't sit on top of these 'humps' and would sit flat on the chassis.
I’ll take pictures of everything on Monday and update the lot so you guys have some 7M eye candy
