Results 1 to 7 of 7
Thread: 4AGZE high idle but no boost leaks
    Junior Member Grease Monkey .:2DR-FTU:.'s Avatar
    New South Wales
    Exclamation 4AGZE high idle but no boost leaks
    Hello all, i have an ae82 with late model 4AGZE. I got this car last week and its had a high idle since. The car has a front mount fitted with no BOV, and idles between 1,500 and 2,000RPM. I dont understand whats goin on as there is no boost leaks (Boost guage sits on -20) and car drives fine. Anyone got any idea's, becuase im sick of people looking at me like im a try hard LOL. Thanks in advance
    Jarrad
    Quote Originally Posted by Cow Cow
    Here in Hong Kong, I have a Echo 1.3
    I put in a TRD exhaust manifold, TRD quick shift gear stick, K & N Air Filter, Ground Cable, NGK E spark plugs, 2 pcs of Voltage Stabilisers and twin HID systems.
    It goes like a rocket.
    Default Re: 4AGZE high idle but no boost leaks
    Youve prob got a vacuum leak.
    A high idle can also be caused by air in the cooling system but this shouldnt affect boost.
    New South Wales
    ok so i found a leak in the piping... fixed that, and i had to adjust the screw on top of the TB. the revs fluxuated still, and im thinking that yeah it maybe the cooling system. Thanks for the heads up
    If they hint then that would be my first port of call. There are other factors that will cause this too but im not sure what they are. Have a search on here as its been mentioned a few times before.
    I see invisible people Backyard Mechanic WHITCHY's Avatar
    New South Wales
    Hey Jarrad,
    I had this happen when I first put in my 4AGE. My TPS was out of whack! Find a 4AG manual and try and adjust it properly, or just loosen it and rotate it a bit each way and see if it changes anything! Mark where its at before ya move it incase ya problem is from air in the water system!
    New South Wales
    hey i just realised i wasnt adjusting the tps.. I yas adjusting the large screw on the throttle body.
    Idle screw?
  1. 4agze chugging noise on idle, s/c bearings noisy
    By sluggish in forum Tech and Conversions
    Last Post: 23-10-2006, 08:44 AM
  2. 1jz: unusual high idle on cold-start
    By bk_ in forum Tech and Conversions
    Last Post: 27-04-2006, 07:25 PM
  3. wiring up a turbosmart duel stage boost controller?
    By -=DV=- in forum Tech and Conversions
    Last Post: 15-03-2006, 03:53 PM
  4. Replies: 22
    Last Post: 15-03-2006, 01:24 AM
  5. High 4AGE Cold Idle
    By toaster in forum Tech and Conversions
    Last Post: 23-10-2005, 03:08 AM
