Results 1 to 8 of 8
Thread: 3SGE TPS Loom Plug Onto 4AGE Loom???
    Backyard Corolla Kid Grease Monkey
    Exclamation 3SGE TPS Loom Plug Onto 4AGE Loom???
    I currently have a 4age in my TE72, now i am missing the TPS Loom Plug, i know that i can use the loom plug from a 3sge as it will bolt to my 4age TPS without a problem...
    the problem im faced with is this...
    the 3SGE Loom plug has the following wires:
    Brown
    Pink
    White
    Pink with Blue Stripe
    The 4AGE Loom has the following wires allocated for TPS:
    Yellow
    Blue
    Red
    Brown
    so i basically need wiring diagrams for both or if someone knows what wires to put where....
    any help is appreciated
    T'ville, QLD
    Default Re: 3SGE TPS Loom Plug Onto 4AGE Loom???
    as long as the wires are in the same order then it wont make a difference, ie if yellow comes first and so does pink then yellow and pink go together, simple really
    2T out 4A in....
    Hoppers Crossing
    newbien - you could also compare a 3SGE wiring diagram and a 4AGE wiring and see what colored wires do what to be 100% certain.
    Hoppers Crossing
    ok so i got bored
    http://users.tpg.com.au/celica23/toy...2_3SGE_EFI.pdf
    BR = E2 (i suspect EARTHed ECU
    W = VTA
    P = IDL
    P-L = VC (common with pin 4 on the AFM)
    on ae92 4age
    Y = VCC
    R = VTA
    L = IDL (L = blue wire)
    BR = e2
    that should get you sorted
    thank you very much guys...
    i can finally wire in the TPS then wire the start panel and test fire it
    T'ville, QLD
    no dude thats not going to work!
    if you have a 4age tps and a 3s plug, mixing the wires around it going to completely fuck everything up, ie lets say for instance a 20v water temp sender plug has 2 wires brown and white and a 1uz temp sender plug fits and has wires black and green, the 20v has the first pin as earth and brown and the second pin as the signal the 1uz is opposite (black is signal and green is earth on first and scond pin respectively), does that mean the brown cut off wire of the 20v loom goes to the 1uz earth (green), NO!!! you bet your fuckin arse it doesnt! You match it up to the wires for 1st 2nd 3rd pin etc, ie in 4age tps the brown is the earth and in pin 4 the 3s earth is brown as well and in pin 1 does one put the brown to the brown wire, NO!!! pin 4 on the 3s (pink blue) is now the earth of the 4a sender
    2T out 4A in....
    Paragraphs would help.
    I've fitted a 3SGE throttlebody + TPS to a 4AGE without changing any wiring.... Everything works as it should. Only thing that was done was that the 3S TPS was flipped around (so it faces the right way. All the pins are opposite normally but this brings them back to the correct order.
    Yeah I've fitted 20v 4age tps to 3s and the pins basically are in opposite order.
  1. 4AGE 100kw into AE92 (where 4AFC used to live)
    By Grega in forum Engine & Driveline Conversions
    Last Post: 24-07-2008, 06:53 PM
  2. AE86 JDM loom plug identity
    By parrot in forum Tech and Conversions
    Last Post: 27-12-2005, 10:58 AM
