Results 1 to 14 of 14
Thread: 4AG 16v Flywheel
    Mar 2008
    Lima - Perú
    Default 4AG 16v Flywheel
    Hi everyone..
    I have a doubt, I expect that you could help me...
    how many bolts has the 4ag 16v flywheel? 8 bolts? is there a version with 6 bolts?
    thanks
    TT141 - 3T/2TG (70%)
    AE86 - 4AG (35%)
    from Perú
    Breaker of all things aka Backyard Mechanic Chrisso's Avatar
    Vancouver, BC
    Default Re: 4AG 16v Flywheel
    Yes, 8 bolts are common though I have a feeling that there was a very early release of 4ages with 6. 4acs are 6 bolts.
    Chris
    AE86 4 shades of silver - The Lone Ranger's steed is on the road again!
    AE86 shell - waiting for a donor car from the auctions.
    Mar 2008
    Lima - Perú
    thanks for your comment..
    that's the thing.. I have a doubt if there are a 6 bolt flywheel for the 4ag.. maybe in the transversal 4AG (MR2)?? the 4A flywheel could be used in the 6 bolt 4AG?
    thanks
    AE86 - 4AG (35%)
    from Perú
    I have never seen a 4ag 6 bolt crank ever, Ive pulled down a AW11 mr2 4age and it was 8 bolt.
    all aw11's have a 8 bolt crank/fly in them
    AB
    I too, have been searching for this mythical beast.(almost 3 years now) I have heard both that its real and exists and that it does not. I can confirm that the 4ac, 4af, and 7af flywheels have 6 bolts. actually what i would really love to find is a 8 bolt flywheel that takes a 190mm clutch. (another mythical creature said to exist somewhere) I have a z50 transmission in the tercel that will not take even the small 200mm flywheel from a 4a, aside from having something custom built i think i'm pooched. or do some fancy building with variious "A" series bottom end parts to have a 4age with 6 bolt flywheel compatability...... could always use a 4ac/f block but possibly need to change pistions for a ge? 4afe cranks are large mains (42mm) but the smaller rod connection (18/19mm?) so you could use it in a newer block but have to salvage rods from an earlier 4ag or the rods from the 4af itself......... anyways im prattling, if you find something let me know.
    Quote Originally Posted by merc-blue
    Cheap tools take all the fun out of working on a car.
    My Rebuild and Conversion.... '81 Tercel 3A -> 4A-GE 20 Valve - ON HOLD.
    BAD ASS 1986 MR2 - Finally Moving forward.
    Vancouver, BC
    To clarify, what I meant to type was that "I'd heard", not "have a feeling". Agree with above comments, have only ever seen 4ages with 8 bolts and 4acs with 6.
    Victoria, Mt Macedon
    If you're looking for a good 6bolt 4AGE flywheel, I seem to remember news (probably 2 years ago now, and maybe on club4ag or aeu86.org) that someone made a batch of nice billet 200mm flywheels, but screwed up and had them drilled to 6 bolt.
    Some of these may still be floating around if that's what you are after.
    Also I concur with the above, despite rumours of 6bolt 4AG flywheels I don't believe they happened.
    Hen
    New Zealand
    i too have searched high and low.
    and the ONLY evidence i have found is on forums.
    never in any Toyota epc, manual, bulletin or anything have i seen a 6 bolt 4age flywheel or crank.
    I have, i have seen a whole three of them. 150mm, made for a 5 1/4" Tilton clutch and the kid who wanted them made screwed up and specified 6 holes not 8.
    I think they found the special bin.
    I though you can get 6-bolt billet flywheels for 7ag conversions? e.g. the Alloy Race Components "Toda" style, i've seen in 6-bolt hole pattern.
    Mar 2008
    Lima - Perú
    mmm... I can tell that nobody have ever seen a 6 bolts 4AG flywheel/crankshaft..
    .. my friend have a 4AG (disarmed) but with a 6 bolts crankshaft.. he dont have the flywheel... this crankshaft must be from the 4A engine? can we use this crankshaft in the 4AG block? with the 4A flywheel? the 7A one? what can we do to use this engine??
    AE86 - 4AG (35%)
    from Perú
    New Zealand
    Quote Originally Posted by thanhngo
    the 7afe has 6 bolt crank, you use that crank when building a 7age....
    South QLD
    Quote Originally Posted by DeftAnesthetik
    . actually what i would really love to find is a 8 bolt flywheel that takes a 190mm clutch. (another mythical creature said to exist somewhere) .
    I adapted a Fiat x19 1500cc clutch to a 4age 8 bolt flywheel . they are 190mm . iam using it a gze making 350hp , the clutch had been up up rated in the clamping force and using a brass button clutch
  1. 2jz flywheel bolt details and flywheel thickness - help ?
    Last Post: 28-12-2011, 03:53 PM
  2. Standard 7M flywheel with 6 puck sprung clutch
    Last Post: 10-04-2008, 02:11 PM
  3. 20V Conversion, need to find a flywheel HELP!
    By DeftAnesthetik in forum Tech and Conversions
    Last Post: 14-07-2006, 04:34 PM
