Results 1 to 9 of 9
Thread: 3SG ST202 engine into ST162
    queensland
    Default 3SG ST202 engine into ST162
    does anyone have a full or partial wiring diagram for a ST202 with 3SG (plain Gen 3 engine, not beams). the computer is not the same as MR2. net search has only revealed US market 5SF engine stuff. Its going into a St162
    Default Re: 3SG ST202 engine into ST162
    http://www.toymods.net/forums/showthread.php?t=5108
    does that help any?
    i've got SW20 wiring diagrams if u need them. no ST202 ones sorry
    queensland
    not really of help, but thanks. I knew all that stuff. I just want wiring manual. I've got the MR2 , gen 3 one , but its quite different
    Tasmania
    terry best bet might be 6gc.com.
    ive got an account there and can put up a topic if your not signed up.
    1973 TA22
    wa
    Would an st 204 diagram help i can get one for you if it will
    queensland
    cuts
    any help appreicated. thanks
    2jzhilux
    the 204 wiring is not the same (its 5SF engine). if you have the entire diagram, the part showing the fuse box might help me.. thanks
    Tasmania
    http://www.celicatech.com/imagearchi...e/94_6gmanual/
    check that one out terry, prob not exactly what your after but its got a shit load on it, in the mean time ill try and get more out of these 6gc noobs.
    1973 TA22
    I like Stuff Backyard Mechanic mikie's Avatar
    i have a few that iv found in a pdf. 5.2mb so i cant upload here.
    http://www.mediafire.com/?rd41ir0inil
    hope it helps
    Cheers Mike
    queensland
    thanks guys, finally assembled enough info. I ended up buying a full harness in UK and then integrating the air-con stuff into that.
    Along the way I did find out that the computer supplied with the engine did not match what was left of the engine harness that originally came, or the UK replacment, so it was a wire-by-wire check it job. should be running soon.
  1. Sams MA61 7MGTE Conversion Guide
    Last Post: 08-07-2015, 12:12 AM
  2. MA70 --> JZA70 Conversion
  3. Engineers Cert. Question.
    By Mk3_supra in forum Tech and Conversions
    Last Post: 07-03-2007, 11:49 PM
