Results 1 to 3 of 3
Thread: Z20/1JZ A/T dash wiring
    Mar 2008
    Alberta
    Default Z20/1JZ A/T dash wiring
    In the process of wiring up my digi dash and modifying an older jza70--> ma71 dash wiring chart to benefit z20 owners. Basically, I need help modifying the ma70 side of the chart/diagram to z20 dash wiring. In this particular case, im interested in modifying the chart for an 89 mz21 with A/T and a digi dash. Any help would be greatly appreciated!!
    http://web.archive.org/web/200512161...IG1(87-89).pdf
    Junior Member Grease Monkey JZA20's Avatar
    Default Re: Z20/1JZ A/T dash wiring
    Hey mate, have you got any further on this? do you know where the a/t wires go? and do you know how the speedo connects up, as the mz20 electric speedo and the jza70 has a analoge speedo.
    cheers josh v
    Mar 2008
    Alberta
    Im am waiting on my jza70 IG1 harness to arrive and then i will comense the wiring mayhem. From what i've pieced together, the wiring is actually very straight forward! 95% of the wiring(colors) between jza70 and z20's are the same or very similar. the main diagram I am using is inthe original post. I plan to modify the diagram to be consistant with an a/t z2x soarer. I havent looked to far into the speedo situation, but i do believe a A/T speedo sensor is required. I will keep this post updated!
  1. RA23 Dash Wiring
    By fuzz! in forum Tech and Conversions
    Last Post: 15-09-2008, 01:57 PM
  2. Jzx81 Dash wiring Diagram?
    By Jzxbenno in forum Tech and Conversions
    Last Post: 17-11-2007, 10:44 AM
  3. JZX81 1JZ: Analogue Dash Wiring
    By mamba in forum Engine & Driveline Conversions
    Last Post: 19-05-2007, 05:04 PM
