Results 1 to 15 of 28
Thread: 2jz flywheel bolt details and flywheel thickness - help ?
    Penrith BC
    Default 2jz flywheel bolt details and flywheel thickness - help ?
    heya
    just after the details of a 2jz manual flywheel bolt.... how long, how much shoulder, how much thread etc
    also, if anyone has a stock flywheel and can measure (or knows) how thick they are at the clamoping face, that would be awesome
    alternatively, im chaing some bolts for the 1uz, that needs to hold down a 12mm thick flywheel. suggestions for compatible bolts?
    + rep....
    ed
    ../delete/ban
    tech moderator
    Forum Sponsor Conversion King
    Default Re: 2jz flywheel bolt details and flywheel thickness - help ?
    measured up 1j bolts? have some, you travel and you shall find, (ill make sure they're still here first)
    linden
    Penrith BC
    me = bed now
    you find bolts, me come over tomorrow
    meanwhile, anyone, anyone?
    ../delete/ban
    tech moderator
    Can't measure thread hole depth, pitch, and diameter, then add flywheel thickness and just source some hi tensile bolts from the nut house?
    Ed; thread here: http://www.toymods.net/forums/showth...+bolt+database
    2JZ Atmo are M10x1.25 They are 26.2mm long.
    Shank diameter is 10mm, shank length is ~4.3mm.
    ARP part number for 8 bolts is [203-2802], which is roughly $35 (http://www.vpw.com.au/product.asp?Ca...15&ProdID=2692)
    They look like this:
    Will measure my 2JZ fly at the clamping face, but im pretty sure itll be the same as my 4AG one in the order of 12mm
    Penrith BC
    could you check the 4ag flywheel?
    just need a bolt to suit a 12mm flywheel.
    interesting though, my auto 1uz bolts look like the 1jzgte/r154 bolts with fuck all shoulder. i wouldvr thought a 12mm flywheel wouldve come with a longer shank....
    i could even get away with reusing my existing auto flex plate bolts...
    ../delete/ban
    tech moderator
    Yeah, my auto 2JZ bolts are just shorter versions of the manual ones. R154 and W58 flywheels are the same thickness, and im pretty sure its 10-12mm. I couldnt get at mine this morning due to the wife being called in for surg 30mins early.
    The auto flexplate bolts will definately be shorter. My auto bolts only get 1-2 threads onto the crank.
    first hand experience
    1j 2j flywheel bolts different
    8.3 et PB 169 MPH PB
    R154 vs V160 yes.
    The part number is the same for all R154 and W58 1JZ and 2JZ engines.
    Penrith BC
    tak, that arp 4ag bolt set, tahts the same as the 2jz/1jz/r154 bolt?
    ../delete/ban
    tech moderator
    Yep, its what i have ordered for my 2JZGE/W58 combo. And what i have used and seen used on several R154 combos.
    Oh yeah, and i use it on my 4AG.
    VPW seem to be slow currently, i ordered last week and havnt heard a thing from them yet.
    Penrith BC
    fyi 1uz auto are M10x1.25 23mm long with 2-3mm shank
    ../delete/ban
    tech moderator
    Ill measure and photo this morning.
    Does this help Ed:
    12.5/13mm thick Flywheel (2jz)
    M10, 10mm shank
    8 or 9mm shank, 26mm overall length.
    They are stock 1/2JZ bolts, pulled off a manualised 1JZ, and also off a stock 2JZ manual.
    From comparisons with other bolts they are exactly the same as my 4AG bolts. With varying degrees of rust.
    Penrith BC
    perfect!
    thank you
    ../delete/ban
    tech moderator
