Results 1 to 10 of 10
Thread: F series Diff flange the same as E series?
    Default F series Diff flange the same as E series?
    Does anyone know if F series Diff flange the same as E series?
    I'd like to change the Z12 diff flange to the much more common F series, as opposed to the current G series it is atm.
    From my MX62 cressida memory the single piece shafts have replaceable unis, and fit to a E series diff...if the E series flange is the same as F series then I might grab the rear flange and uni from a MX62 cressida...
    It'll make it easier to put different diff ratios in it (i.e. the MA61 lsd I have for it)...I won't have to change the front flange on the diff...
    no backyard Domestic Engineer japlish's Avatar
    Default Re: F series Diff flange the same as E series?
    umm arn't mz12's the same as ma61's?
    Destroyer of 'Drop Forged' spanners
    Quote Originally Posted by japlish
    No.
    MZ12 Auto has an F series diff (3.58 ratio) with a G series flange.
    The MZ12 Auto tailshaft has the larger G series (hilux) style replaceable uni as well. MA61 has smaller non-replaceable from factory unis.
    MZ12 rear shaft is also longer than MA61, and the MZ12 auto yoke is A340E not A43D as found in the auto MA61.
    As a not MZ12 Manual actually has a G series diff according to the EPC...
    tasmania
    i'm 90% sure they are.
    beer me!
    tasmania
    just checked the various diffs i have
    the bolt patterns are the same, not 100% sure on the spigots though as the E diff was still in car with tailshaft attached.
    bolt pattern was 55mm square (EDIT: may not be square, i didn't check), ~77mm PCD. the spigot on the F diff is 45mm dia.
    beer me!
    I just went and did a quick measurement of what I have..
    joecoolmk2: Any chance you measured the F spigot to be 46mm as opposed to 45??
    F Series Diff Flange: (RA65 Diff)
    55mm x 55mm Square [Checked]
    ~45.9mm Center bore clearance for spigot on tailshaft flange (~45.85mm OD for spigot on tailshaft flange) [Checked]
    G Series Diff Flange: (MZ12 Tailshaft)
    60mm x 60mm Square [Checked]
    nuts Grease Monkey
    auckland
    ive seen at least a couple different bolt pattern on F series diffs. the smaller size same as T series
    would anyone have one of these G series mz12 diffs available for sale? even just the housing and shafts
    -Mark
    E2 + E7 fan
    tasmania
    yeah could be, i just glanced quickly over it with a tape measure.
    beer me!
    Junior Member Backyard Mechanic pete05's Avatar
    penrith nsw
    Wilbo if you want to part with that g series yoke for the f series diff just let me know as you may remember i was looking for one before.
    Pete
    Quote Originally Posted by pete05
    Pete
    I'll prbly be looking to sell the whole diff, but I'll keep you in mind
  1. g series diff whoes PLEASE HELP ME!
    By SillyCarS in forum Tech and Conversions
    Last Post: 01-03-2008, 11:28 PM
  2. s series diff info needed
    By styler in forum Tech and Conversions
    Last Post: 04-12-2006, 03:40 PM
  3. G series diff database
    By bansheebuzz in forum Tech and Conversions
    Last Post: 01-05-2006, 11:36 PM
  4. F series diff measurement.
    Last Post: 03-11-2005, 05:18 PM
