Results 1 to 9 of 9
Thread: how to boost power to starter
    Studying to become a Domestic Engineer warrior's Avatar
    New South Wales
    Default how to boost power to starter
    I have wanted to post this up for quite some time,
    does your car go click click click when u turn the key, but you know the starter is fine.
    all those people out there who changed their starter motors and spend hard earned $$$ only to find out that the starter was fine in the 1st place. this is mainly required for older cars where the wiring and clips are starting to become brittle.
    this is the relay required
    you will need to locate the start wire on the engine harness, normally located near the starter or on the starter it self.
    here is what you have to connect to where.
    30 - positive terminal on battery
    86 - negative terminal on battery
    87 - wiring harness (right plug in bottom pic)
    85 - to starter / wire (left plug in bottom pic)
    it is quite a simple fix, you can either use crimp plugs or solder the wires on. your choice, depends on how fussy you are.
    hope this helps. tried to post in the FAQ's but i am currently not entitled to do so.
    Karl
    Photographer and Backyard Mechanic Rinmax's Avatar
    Default Re: how to boost power to starter
    Nice little tutorial. Well done
    "It's an ingenious solution to a problem that should never have existed in the first place." - JM
    "A Ferrari is a scaled down version of god while a Porsche is a Beetle with mustard up its bottom." - JC
    So you are fixing up the wires going to the solenoid?
    Also try adding a better earth to the engine, nice thick battery cable with some big crimp connectors. I bolted mine between the starter body and the chassis and it worked wonders.
    New South Wales
    Quote Originally Posted by RobertoX
    nah, the starter motor wire requires a certain amount of current from the key start, when the wires get old and brittle they dont send enough power, this will boost power to that wire/starter.
    Karl
    Junior Member Domestic Engineer NeoNasty's Avatar
    Friggin excellent. I am about to do this for my GF;s car. I was going to work it out myself. but then BAM! someones done it for me.
    Champ! +rep for you!
    HZJ75, RS41, JZZ30
    copied to FAQ and editted to make it better.....
    AE86 Tuning Life Backyard Mechanic Garth AE86's Avatar
    Sydney NSW
    so for cars which yoiu have to bash the starter with a spanner to make it work this wont help?
    Garth - 100% AE86 Addict
    AE86 - Levin & Trueno - The Legends Live On!
    'AE86' - Toyota Sprinter Trueno GTV
    "It's not a street car if you can't drive it on the street. The car has to be safe and fast on any road condition" - Keiichi Tsuchiya
    New South Wales
    Quote Originally Posted by ae86drift
    people who have a starting problem and have to bash their starter, should try this 1st, it is quite common to buy a new/reco/used starter and still have the same problem, thats why this i created this thread
    Karl
    sa
    Had to do something similar to bypass the ballast resistor on a couple of my ke30's back in the day. It cranked fine, but it wasnt getting enough spark. Basically the same wiring for the relay (during cranking) and it skipped over the ballast resistor.
  1. 4AGE reduction starter clarified
    By parrot in forum Tech and Conversions
    Last Post: 28-11-2011, 08:09 PM
  2. TA63 boost spike problem
    By Diz44zy in forum Tech and Conversions
    Last Post: 28-01-2006, 11:44 AM
  3. 3K starter pinion center distance from crank center?
    By 510rob in forum Tech and Conversions
    Last Post: 14-01-2006, 08:34 PM
  4. Tips on replacing the starter motor in an RA65
    By azmodai in forum Tech and Conversions
    Last Post: 22-12-2005, 05:12 PM
