Results 1 to 2 of 2
Thread: MS123 Hub Wheel studs - longer
    I have a pet Backyard Mechanic Gibbon's Avatar
    Aug 2006
    Question MS123 Hub Wheel studs - longer
    Hi
    Got MS123 hubs on my MA61 - they needed a 5mm spacer behind the disc for everything to line up nicely.
    Now - a few people have commented on how there is very little thread for doing up the wheel nuts. There is about 4-5 turns max before they are tight.
    Two questions:
    1 - Are these the right ones to replace them with - http://www.niceproducts.com.au/catal...el/wheel91.htm
    Part num: NS3400 - I'll ring the company on Monday - but just wanted to run it past you.
    2 - Does the hub need to be removed to swap the wheel studs over? Or can they be pressed out on the car?
    Thanks
    wget -r http://www.toymods.net | grep -i "1jz MA61"
    1 Result found:
    Gibbons MA61 + 1JZ
    Junior Member Domestic Engineer ill-minded's Avatar
    May 2006
    Default Re: MS123 Hub Wheel studs - longer
    according to cruzida, the studs you're looking for are nice products number S315
  1. Need longer wheel studs suit AE82 rear hub PCD 100x4
    By MaNGeW in forum Tech and Conversions
    Last Post: 15-10-2007, 01:09 PM
  2. The SW20 "How To" Thread - Step By Step Guides
    Last Post: 30-09-2007, 10:49 PM
  3. st162 wheel bearing/stub axle
    By BeRad in forum Tech and Conversions
    Last Post: 15-10-2005, 09:29 AM
  4. Replies: 4
    Last Post: 08-09-2005, 01:17 PM
