Results 1 to 14 of 14
Thread: 1JZ-GTE vs 2JZ-GTE JDM Cam Profiles
    Default 1JZ-GTE vs 2JZ-GTE JDM Cam Profiles
    I've taken some measurements off my 1JZ-GTE and 2JZ-GTE JDM cams:
    1JZ-GTE Exhaust Cam: Peak ~7.98mm @ ~328Deg
    1JZ-GTE Inlet Cam: Peak ~7.72mm @ ~34Deg
    2JZ-GTE JDM Exhaust Cam: Peak ~8.67mm @ ~328Deg
    2JZ-GTE JDM Inlet Cam: Peak ~8.08mm @ ~41Deg
    Base circle ~36mm.
    These values seem to differer from the quoted values, so I double checked the max lifts with a micrometer, and got within about 0.03mm from all 4 of my dial gauge recorded readings...
    Anyway these are just the values that I recorded... I wouldn't base anything too important off them
    I'm happy to email the excel spreadsheet with my measurements to anyone that wants it, just let me know. And if someone wants to host it that is OK by me too.
    Default Re: 1JZ-GTE vs 2JZ-GTE JDM Cam Profiles
    Is that lobe lift or cam follower lift??
    Top work Wilbo. you got my email address don't you?
    Now grab that exhaust cam off Pete for the US spec one
    QUICKEST 1JZ'S IN OZ
    Quote Originally Posted by amichie
    Lobe.
    Righto, Chris I'll email it off to ya!
    Lobe.
    Hi Wilbo
    Can you please send me the excel sheet. I have a program that converts lobe lift to valve lift. All I need is the lobe lift + the base circle diameter which you have already stated above.
    Thanks Andrew.
    [email protected]
    I'll email it off
    2JZ Nut Grease Monkey 98SZR's Avatar
    Jan 2007
    Some very good info there.
    +rep
    Only question I have is compared to official stats for 2jz, the only thing could be if they are US stats, I'd rather have proven tested info (yours) than some unknown webpage:
    Valves: efi/twin cam/24v
    Intake valve dia. 33.5 mm
    Intake valve lift 7.8 mm
    Exhaust valve dia. 29.0 mm
    Exhaust valve lift 8.4 mm
    Intake opening 3 deg BTDC - 41 deg ABDC
    Exhaust opening 52 deg BBDC - 4 deg ATDC
    Quote Originally Posted by 98SZR
    +rep
    Only question I have is compared to official stats for 2jz:
    Glad someone brought that up...
    http://mkiv.supras.org.nz/specs.htm says
    Inlet Cam Lift: 7.8mm
    http://www.turbosupras.com/pages/en/...ZA80/jza80.htm
    Intake Camshaft lift: 7.88mm
    Exhaust Camshaft lift: 8.4mm
    http://www.toymods.net/forums/showthread.php?t=10384 [chris]
    Intake lift
    1jz: 7.61
    2jz: 8.16
    Exhaust lift
    1jz: 7.6
    2jz: 8.66
    http://crower.com/cat/import/toyota/...amshafts.shtml
    Stock Factory O.E.M. specs (2JZ-GTE) for turbo 248 / 248 200 / 204 .338" inch .346"
    Inlet: 8.58mm
    Exhaust: 8.79mm
    Seems a lot of people list a lot of different values...! The good thing about doing something yourself is that you get to find out for yourself
    Jan 2007
    Also sorry yes did see how you mentioned they differ, just wanted to know why
    Found a good sheet with an overview of all 2jzgte engines, good to get all the figures! Link here: http://www.turbosupras.com/pages/en/...ZA80/jza80.htm
    The figures that others have in my opinion must be wrong...
    The EPC lists only 1 exhaust camshaft for the 2jz-gte, and 2 inlet camshafts for the 2jz-gte (one JDM, one USA)...
    So I find it a bit disturbing that there are so many 2jz-gte lift values floating around...either my EPC is wrong or some of the measurements floating around are wrong (and hey that might be mine!)...!
    ...I'd personally take em out to save cluttering the thread, leave a link in you want, but it doesn't really bother me either way
    Btw if anyone has a 2jz-ge inlet camshaft I'd be interested in seeing how that stacks up, and if the 2jz-ge inlet cam can fit the 1jz-ge and 2jz-ge heads (the exhaust cam won't fit because of the dizzy drive gear but the inlet might?)...
    Jan 2007
    Done mate. Yes there are so many figures out there floating around, but I'd rather measure them myself or get the measurements you have taken then some unconfirmed internet stats. As an example they call my paint code Grayish Green Mica Metallic (6NO) when it's real Toyota colour is Moonstone Pearl (6NO), so you can never be sure info is going to be 100% correct on the intraweb!
    Will check my manuals and EPC at home tonight and see what they say.
    Supra Addict Grease Monkey Enigma-Penguin's Avatar
    Aug 2006
    +rep (if I can, I did it for the another thread before )
    The ones I used to ref off were these:
    Intake Exhuast
    1jz-gte
    lift 7.69 7.95
    duration (adv) 224 228
    duration @ .050" 189.1 194.1
    lobe centre
    2jz-gte USDM
    lift 8.25 8.4
    duration (adv) 233 236
    duration @ .050" 200 205
    lobe centre
    2jz-gte JDM
    lift 7.8 8.4
    duration (adv) 224 236
    duration @ .050" 205
    lobe centre
    2jz-ge
    lift 8.3 8.3
    duration (adv) 230ish 230ish
    duration @ .050"
    lobe centre
    HKS 256 for 1jz
    lift 8.7 8.7
    duration (adv) 256 256
    duration @ .050" 211.8 210.4
    lobe centre 110 115
    HKS 264 for 1jz
    lift 9 9
    duration (adv) 264 264
    duration @ .050" 221.2 220
    lobe centre 110 115
    Crower small core 272 for 1jz
    lift 8.7376 8.7376
    duration (adv) 272 272
    duration @ .050" 218 218
    lobe centre
    I knew there were plenty of values floating about, but its nice to have some solid figures ( I love how they use "ish" on some figures). I'm tempted to measure my HKS 264 IN/EX ones now. I thinks I need a micrometer
    Forum Sponsor Conversion King
    Dec 2006
    i is confused,
    i have a 2jz-ge here if you want me to check the inlet but if you want to know if it fits the gte heads id guess no as it probly won't have the triggers for the cam pos sensors, i can check on teh weekend if you would like.
    linden
    i is confused,
    linden
    You are right, that won't work then, I didn't think of that
    Scratch that idea
  1. 2jz Bottom End 1jz Head
    By P.I.M.P.I.N. Soarer in forum Engine & Driveline Conversions
    Last Post: 17-04-2013, 06:27 PM
  2. 2JZ Water Pump onto 1JZ
    Last Post: 28-10-2008, 11:33 PM
  3. Quick Question: 1JZ and 2JZ flywheel bolts the same?
    Last Post: 01-05-2008, 02:42 PM
  4. 1jz to 2jz
    By HIZOKU in forum Tech and Conversions
    Last Post: 30-11-2006, 07:52 AM
  5. 1jz vs 2jz heads
    Last Post: 04-05-2006, 10:07 AM
