Results 1 to 15 of 16
Thread: Tech Data: 1JZ-GTE vs 2JZ-GTE Map Sensor Pressure vs Output Voltage (Identical)
    Default Tech Data: 1JZ-GTE vs 2JZ-GTE Map Sensor Pressure vs Output Voltage (Identical)
    Conclusion: 1JZ-GTE (JZZ30) Map sensor is the same as 2JZ-GTE (JZS147) Map sensor.
    The MAP sensors appear to read to ~17.5psi (4.92V output).
    Tested using a Blitz DTT (Dual Turbo Timer / Boost gauge) as the reference. I've also tested the Blitz DTT versus two individual mechanical boost gauges (An Autometer and a Speco) so have quite a degree confidence in it.
    Some other discussion is in this thread...
    http://www.toymods.net/forums/showth...1jz+map+sensor
    Default Re: Tech Data: 1JZ-GTE vs 2JZ-GTE Map Sensor Pressure vs Output Voltage (Identical)
    Good to know, that puts another internet myth to rest.
    The Trust E-manage Ultimate supports this too.
    Supra Addict Grease Monkey Enigma-Penguin's Avatar
    Aug 2006
    Nice to see another myth put down +rep for that. *hugs his greddy map sensor*
    lol deja vu!
    http://www.toymods.net/forums/showthread.php?t=15998
    Good work Wilbo, I hope you didnt go to all that trouble then find my thread!
    It was fun putting this info to the soarercentral boys. They didnt take it as easy as i thought as a LOT of them have been using the 2JZ map sensors as FCD style UPGRADES! haha
    JZA70|R / 12.45 @ 111 mph.
    Quote Originally Posted by JZA70 R
    lol deja vu!
    You'll notice in my post that I linked to your thread!
    I think that my data is a little bit more empirical and maybe a little more generally useful than yours (shows a little extra information, mV/psi, voltage per specific psi etc)...also I like to check things first hand! Your results agree pretty well with mine, we just went about it different ways btw I did rep you for it
    Anyway I had an ulterior motive for doing this, along the lines of a configurable boost cut defender / MAP interceptor )...I just thought I'd put up my measurement in the hope that it might help someone one day!...I might post more about my MAP interceptor too, when / if I get it working
    Good stuff, top work +rep
    Junior Member Grease Monkey Neal_411's Avatar
    Good job there, very interesting to see.
    Not a Domestic Engineer Phyro's Avatar
    Yeah this oughta help me soon or later, cheers
    '88 GZ20 & '86 MZ11
    Strange they didn't give it the same part number. Toyota are the world best in lean manfacturing if they could have used the same part in two different models i would have thought they would have.
    Alex
    RA28 Turbo 18RG
    RT104 - spare toy
    BF II XR8
    Quote Originally Posted by ra_28
    Alex
    The 2JZ one bolts to the inlet, the 1JZ mounts to the firewall.
    The number of times toyota change something when they don't need to is crazy IMO!... :S
    Last edited by wilbo666; 18-11-2007 at 11:53 AM. Reason: Well spotted by phyro that I said 2jz was in two different spots :P
    The 2JZ one bolts to the intlet, the 2JZ mounts to the firewall.
    Schizophrenic bastards then aren't they??
    '88 GZ20 & '86 MZ11
    Quote Originally Posted by Phyro
    Hahah, DOH...slaps head *and goes to correct post... *
    Well spotted
    User Conversion King
    NWA
    so.....
    what voltage does the ECU say 'fuck-you' and cut fuel?
    (making a FCD)
    hello
    4.3v I believe.
  1. 1JZ > 2JZ Map Sensor Upgrade Myth Burried.
    By JZA70 R in forum Tech and Conversions
    Last Post: 14-11-2008, 09:45 AM
  2. 2JZ Water Pump onto 1JZ
    Last Post: 28-10-2008, 11:33 PM
  3. 550cc US 2jz injectors into 1jz
    By Esselte in forum Tech and Conversions
    Last Post: 26-07-2007, 02:18 PM
  4. 1jz to 2jz
    Last Post: 30-11-2006, 07:52 AM
  5. 1jz vs 2jz heads
    Last Post: 04-05-2006, 10:07 AM
