Results 1 to 8 of 8
Thread: Brake Caliper Pistons
    Junior Member Domestic Engineer ill-minded's Avatar
    May 2006
    Default Brake Caliper Pistons
    after having a quick search, i didn't really find anything conclusive, so i thought i'd start up a thread on this.
    basically, i bought some 300zx calipers for the xA6x brake upgrade and i've just finished tearing the calipers apart (with only a 14mm spanner... ) so i can clean, repaint and rebuild them. anywho, after i pried the pistons out of the calipers (and after skinning my finger and foot in the process), i noticed that the pistons have got some crap on the surfaces as shown in the pictures below.
    http://img.photobucket.com/albums/v5.../IMG_0362r.jpg
    http://img.photobucket.com/albums/v5.../IMG_0363r.jpg
    the ones in the first picture didn't bother me too much as its not really that much and that they're near the top of the piston so they sit above the seal anyway. the ones in the second picture are from the other caliper and the marks come down a bit further as well as just having more marks to start with. other than these marks, the pistons have no other signs of damage (pitting or scratches).
    i've tried a little bit of degreaser on a tissue to see if the marks would come off, but they don't so i was wondering if it would be alright to use a bit of light steel wool to see if it would remove the marks or if this would adversely affect the sealing ability of the piston later on. or alternatively, if its not even worth worrying about, i'll just clean them up as much as possible and continue on my merry way.
    so anyway, if someone has some input i'd love to hear it
    Default Re: Brake Caliper Pistons
    are you sure it is not the coating coming off?
    if not, i would be happy to attack it with some wet, 1200grit wetndry... steelwoll might be a bit harsh.. then again, it might be softer than the coating
    got any copper steelwool stuff?
    May 2006
    i just had a quick little try on a small section with some 1000grit wet n dry (all i have at the moment) and it seems to be doing the trick without leaving any marks on the surface, so it looks like that might be the go, but we'll see how things turn out. man it sucks being a poor college student.. no money and no space and technically i don't think im supposed to be doing this in my room haha
    May 2006
    ok, so i just finished doing that piston and it worked a treat.
    so, for future reference, fine wet'n'dry works fine at getting these marks off, whatever they were. it was a bit hard to tell but my guess is it that the calipers probably haven't been actually on a car for a while so the seal or something left some little marks on piston surface.
    many thanks to you OC need to spread the love around first though
    Junior Member Backyard Mechanic maurice c's Avatar
    Yes we Canberra
    Try some metal polish it usually cleans them up real good, you have to make sure that you remove all traces though with something like brake cleaner.
    Getting your missus to help bleed the brakes isn't everybody's idea of quality time.
    you can also try soaking with a fine mineral oil like white-spirit or dry cleaning fluid and gently rubbing the marks (still wet) with a green kitchen scourer.
    Just be aware that those things can scratch soft metals - and those kinds of oils require gloves and the gloves/scourer will have a very short life when wet with those oils.
    sa
    It's chrome plated. If you're really worried, take them into PBR and get them re-plated. I did some a few years ago for something like 30$ for 2. For that price, it's worth the peace of mind
    thats nothing, just hit them with some red scochbrite or 1200 wet and dry and chuck them back in,
    By The Witzl in forum FAQ
  2. Pistons - Cast vs Forged vs Hypereutectic
    Last Post: 21-11-2006, 02:04 PM
  3. break upgrades/ta23
    By buztoy in forum Tech and Conversions
    Last Post: 14-10-2006, 08:00 PM
  4. Brake Caliper Weights
    Last Post: 13-05-2006, 12:54 PM
