Results 16 to 25 of 25
Thread: 3SGTE in AE82 Corolla
    Sweden
    Default Se82
    I've got a generation 2 3S-GE in my AE82.. I guess the GTE will fit as well, although I think it will be a tight fit and the cooler will probably need to be moved. Two of the four engine mounts need to be modified.
    The engine bay of the AE82 is as wide as the one of the ST162, but it is shorter.
    The intake manifold just clears the firewall and there is not many mm's of air between the exhaust header and the cooler. Also, the upper coolant hose exits the cooler straight into the header, so I will probably use a ST162 cooler instead of the AE82 one.
    You can check out the pics from my conversion (it is not ready yet) at http://pugho.no-ip.com/gallery/stuff/Keffo/
    AGE-16V Automotive Encyclopaedia Dimmy's Avatar
    Default Re: 3SGTE in AE82 Corolla
    i've seen a few of these conversions, and probably wouldn't recommend doing one unless you're good at custom/fabrication work because to get the engine into the engine bay is an effort in itself. There's about 5mm room between the chassis and the engine
    They do make fairly good power stock, but then again the 4age/t/z are much easier to install and have the potential to make huge power
    I have been pruned by old man river!!!!!
    Forum Sponsor Grease Monkey
    Quote Originally Posted by piggy
    theres a camary turbo getting around here in newcastle
    first time i saw it i went wtf camary turbo never seen thst before
    If it was blue it was mine
    easy/cheap conversion and heaps of fun
    Quote Originally Posted by camrygt?
    If it was white it was mine
    good value
    cyas
    mark
    Dreamer Backyard Mechanic millsi's Avatar
    why not use a supra gbox?
    um... are you serious or just s#5tstirring?
    hang on a sec. im really not down with all this ae82, jza70, etc stuff. i have no idea what year it is what but now im asuming that the ae82 isnt rwd lol!!
    is there a topic on here which has the years to models details
    ie ta22, 72-74 celica or whatever??
    Carbon neutral Carport Converter Jt_70R's Avatar
    cause the 3sge is a FWD setup engine!
    yes i know.
    my hilux has it setup as a rwd motor, and is using a supra gbox!
    thats why i jumped to the concusion lol!
    Toyota traitor Automotive Encyclopaedia GBC_069's Avatar
    i ll take the spare 3s-gte off ya if you wanna sell it !!!! send us a PM if interested.
    NOW - 2002 WRX STI - WRC Blue 180awkw @ dyno day 20
    WAS - 1991 GT4 GRP A no. 68 153awkw, 13psi @ dyno day 18
    WAS - RED ST162 JDM 86kw @ dyno day 12
    By The Witzl in forum FAQ
  2. 3sgze Vs 3sgte
    By NeoNasty in forum Tech and Conversions
    Last Post: 18-02-2006, 04:03 PM
