Results 1 to 15 of 16
Thread: 18rgeu + TURBO
    Apr 2007
    queensland
    Default 18rgeu + TURBO
    ok all i have been in hiding for a little bit and doing some reflection on my ra23, my ra23 houses a 18rgeu under the bonnet with a haltec e6x ecu. now a little bit back i was in the market to sell the 18rgeu and get a 1ggte for the beast but no one wanted to pay the worth of the motor so, i have driven it around some. in my relection time i have managed to come across a turbo off a 1jzgte, a customer at work has a supra with a 1jz in it and took the turbos off it and put some garrets on it. so i have scored one of the turbo and am looking to put it on the the 18rg to run some small boost until i do some upgrades to the motor and a rebuild. i am looking for a little guide on what to do to hook the turbo up, i have sorced a manifold and a front mount and the turbo. just need to hook it up.
    Forum Sponsor Conversion King
    Default Re: 18rgeu + TURBO
    i personally wouldnt start with a 1j turbo as there isnt much to upgrade to that will bolt on, and the fact that its designed for a 1.25lt.
    try a t25g off an sr20 as it will give good response and moderate power with alot of upgrade turbos available also.
    as far as hooking everything up, if your more specific i can help you but there are 4 lines that need to be run. an inlet for air, outlet to IC and the mani and dump.
    linden
    Apr 2007
    queensland
    yeah its a starting block, i m going to build a 18rgetu, with 22r pistons and crank, the 18rgeu head and a turbo on that, i am only looking to run like 6psi. s for hooking up its a externaly waste gated turbo i need to know what to do to hook it up to the system.
    User Conversion King
    NWA
    1JZ turbo (CT12A) is only good for about 115ish kw
    unless your talking about the VVti turbo
    hello
    Apr 2007
    queensland
    this is on back burn atm its we dont know bout the waste gate we have
    A wastegate is a wastegate.... isnt much too em.
    1J turbos are internally gated. Why does it matter?
    www.usell4me.com.au - We buy and sell cars for private clients
    www.scorpionaustralia.com.au - Australia's only street legal race car!
    I'm selling a series IV RX7 turbo and a manifold to suit an 18R-G. That's a much better fit for your engine, a single CT12A is way too small.
    i keep forgetting to ask how much you want for that norbie?
    Banned Backyard Mechanic Scoobzd's Avatar
    Apr 2007
    second that notion of price from norbie
    Asking $400 for turbo + manifold.
    should probably move this discussion to the 18RGTE reference manual.
    http://toymods.net/forums/showthread...ghlight=18rgte
    that way it can benefit all those who are subscrided to it.
    (\__/)
    (")_(")
    livin on the edge as a Grease Monkey Snyper's Avatar
    south australia
    would ya look at that, it's going to bolt staright up and be the easiest of turbo conversions..
    I'd be taking him up on his offer..
    don't bother with the little 1j turbo, there's a reason they use 2 at a time.. apart from this conversion that Norbie has I'd personally be going with one of the "T" Garret turbo's, T25
    T28 etc
    Do the job once mate and do it properly, don't waste money on half the job only to do it again properly later.
    good luck with it.
    Brendon
    Daily - Prado 90series
    Work - T908 620hp Cummins ISX
    Shed - 1975 TA22 2TG
    Apr 2007
    queensland
    ok just to clarify the ct12a is a internally waste gated turbo
    You've had that for at least 5-6 years, cant believe you've still got it, lol. I remember eagerly watching your celica web page for updates back in the day.
    Brings back memories.
    Last Post: 03-05-2009, 06:47 PM
  2. Tips for my high comp turbo gen 3 3sge
    By trd3sg in forum Tech and Conversions
    Last Post: 26-02-2008, 12:43 PM
  3. unusual turbo/ exhaust question
    By ae10 in forum Tech and Conversions
    Last Post: 07-05-2006, 05:27 PM
  4. Damaged turbo
    Last Post: 28-04-2006, 07:42 PM
