Page 1 of 11 123 ... LastLast
Results 1 to 15 of 157
Thread: 2JZ-GTE into MZ12
    User Conversion King
    NWA
    Default 2JZ-GTE into MZ12
    a couple questions coming to mind so far...
    1. the AC compressors on the 1jz/2jz have 3 wires in the plug. one to excite the clutch electromagnet, the other 2 for some sort of sensor (pressure?).
    2. the aristo auto is allegedly a a340le with the 3 prong fixed yoke thing. before i go to all the effort of undoing the bolt in the back to remove the yoke, is the spline the same as the other a340e slip yokes?
    the car was factory fitted with a a340e (probably first car ever to receive it) so im crossing my fingers that the Z12 yoke will go straight in. there is no dust cover but im sure something could be sorted if it did fit.
    3. i have no plans to change the dumps unless its going to clash with the steering shaft, should i pre-loosen the exhaust bolts before i go to drop the engine in? (norbie, joorsh?)
    anyway thats it for now
    cheers,
    Brett
    hello
    Default Re: 2JZ-GTE into MZ12
    1) Ignore the other 2
    2) nope
    3) yes
    NWA
    re the tailshaft, im wondering if the spigot could be chopped off and a normal slip yoke inserted. pic below shows the aristo type shaft and mx83/JZA etc type slip yoke shaft.
    only real concern is if there is enough overlap of the shaft and the slip yoke.
    thoughts?
    http://img390.imageshack.us/img390/1...aftchopmo0.jpg
    hello
    I would suggest moving that engine back, it's way too far forward. There's no point having the engine in a silly position just because it's a bit easier to bolt up the transmission. Note if you move it back to the correct location (ie engine nearly touching the firewall) you'll have a better chance of getting the shifter to fit.
    As for the dump, removing the valve thingy will permanently disable the sequential system. I got a dual 2.5" dump fabricated to get past the steering shaft.
    NWA
    the shifter isnt a problem as it is staying auto. its only a matter of shortening/lengthening the selector rod.
    i think it also looks like there is a lot of clearance as the soarer looks to have a more recessed firewall. but yeh, maybe a inch or 2 and it should be sitting where yours is.
    cheers,
    brett
    hello
    NWA
    ive removed the collector but left the valve housing section in there .
    it looks like it possbile to leave the sequential system in tact and route a collector past the steering shaft.
    here is a collector roughly held in place.
    hello
    I agree. You'll have heaps more room on the front of the motor to put in a proper thermo fan set-up and room to change anything if the need arises.
    www.usell4me.com.au - We buy and sell cars for private clients
    www.scorpionaustralia.com.au - Australia's only street legal race car!
    NWA
    after playing with the engine mounts more, the engine was pushed back 25mm so that the xmember rubber mount bolt was approximately in the centre of the 4 engine mount bosses on the block. they look very much like the bonneville items now.
    the driver side mount is made at least stick welder FTW!
    hello
    Move it back as far as you can.
    Either the sump or the firewall will stop you.
    NWA
    yep
    theres basically 8-10mm (one finger) clearance between the sump and the xmember now
    however easily a hand space between the head and the firewall
    might test fit the Z12 gearbox member tomorow. check the height and whether there is enough space in the xmember for the larger type mount this box has
    hello
    Looking good,
    As said move it way back
    Also I'd be measuring the stock height of the output of the auto (from the body of the car to the center of the gbox output shaft, or equivalent)...that way you can make the mounts so that gearbox centerline is as per factory -> right driveshaft angles / make the gearbox mount so that the gbox is at the right height.
    Junior Member Grease Monkey BMWTurbo's Avatar
    Jan 2007
    Make sure you fit a 'restrictor' (2.25inch dia cone) in the exhaust also, else you won't be able to control the boost.
    If you are retaining the Aristo 'spider' try and line the gearbox axially to where the nose of the diff is, else you might find you get harmonics in the driveline due to the fact the rubber donut is not really designed to work as a uni joint.
    Subscribed, will have a look at the photos later. Brett, your a nut, see ya at the end of the month.
    NWA
    the other engine mount is half made so atleast some progress has been made tonight
    Quote Originally Posted by BMWTurbo
    care to explain in more detail? consequences of more boost?
    doesnt look like the donut is useable, its physically too big
    hello
    You won't be able to control the boost, will overboost no matter what you do...
  1. 2jz Bottom End 1jz Head
    By P.I.M.P.I.N. Soarer in forum Engine & Driveline Conversions
    Last Post: 17-04-2013, 05:27 PM
  2. 2JZ Water Pump onto 1JZ
  3. 1jz to 2jz
  4. 2JZ damaged, other options?
    By jzk25 in forum Tech and Conversions
    Last Post: 11-07-2006, 05:47 PM
  5. 1jz vs 2jz heads
