Page 3 of 11 FirstFirst 12345 ... LastLast
Results 31 to 45 of 157
Thread: 2JZ-GTE into MZ12
    User Conversion King
    NWA
    Default Re: 2JZ-GTE into MZ12
    got a banjo-banjo flexible line off a AE112 corolla today.
    i also picked up the throttle cable and installed it.
    the cable does about 3 laps of the engine before it connects to the TB
    hello
    Wilbo, Brett is the ultimate cheapskate (has to be... hes a uni bum ) so stuffing around is required to find the cheapest solution. Looking good Brett, you gonna have it going for when I get there on Thursday Oh, and my 28 is just a couple of hours waiting in line away from being registered
    Don't get me wrong I've been there (I put the JZA61 together while I was going through uni ), that's why my z12 is a little different. While I didn't cut any corner per say on the JZA61, it really was done to a budget!
    The z12 I'm doing....trying to not make it quite so budget like lol
    On a side note, nothing wrong with brett's solution at all! I'd do it too if I had an oxy
    What's that donut thing in between the tailshaft and the gearbox?
    Facebook | LinkedIn
    It's a rubber insulator used in lieu of a universal joint, for NVH reasons I believe. Most modern Toyotas use this setup.
    Junior Member 1st year Apprentice onboost's Avatar
    Aug 2006
    victoria
    hey ppl just some VERY useful info that rubber donut can be removed and a slip on yoke can be used from a hilux. It ll take you a while to find one but it does work and makes things alot easier. This is a way we tackled 1uz into mx83.
    Quote Originally Posted by onboost
    Yeah but the spline engagement length is way shorter than the normal auto...
    As per the pic posted earlier
    http://img390.imageshack.us/img390/1...aftchopmo0.jpg
    Looks like a standard W58 shaft spline, but just over half the length... Not ideal for a 2JZGTE...
  9. #39
    NWA
    holy batman it runs
    didnt connect the auto trans line initially so oil went everywhere..... oops
    hello
  10. #40
    NWA
    layed out all the radiators i had and have come up with something that should work.
    consists of; MX73 radiator, MX83 shroud and JZA70 hydro fan. clearance seems about similar to the JZX81 setup. the shroud i got is cracked so i just hacked it up roughly (non reusable).
    i just need to find a non cracked MX83 shroud and mount the hydro fan
    on the plus side, the MX83 shroud can also house a smaller (approx 6") electric fan
    i did get an aristo radiator with the engine but its waaaaay too big
    pics
    hello
  11. #41
    NWA
    in between working over the weekend i got some time in with the car.
    i was mock fitting all the heat exchangers.... and there is quite a few
    one thing im thinking of doing is feeding the power steering rack outlet and the hydraulic fan outlet through the one cooler. in simple terms, a T piece on either end of the oil cooler. it would still use 2 reservoirs, 2 pumps however just one cooler. whether this works im not sure as there may be problems with one reservoir syphening into the other.
    the other option is to feed the hydro fan oil through the MX73 trans cooling line in the bottom radiator tank. there may be a problem with this also as thee hose size is much smaller. i dont want create pressure between the hydraulic motor and the cooler.
    the oil coolers in the pics are MS123 trans coolers.
    the power steering reservoir can be seen where the factory coil was and the hydro fan resevoir can be seen behind the drivers side headlight.
    the intercooler piping will be going through the power steering line hole in the front apron on the driver side. on the passenger side it will go through the triangular hole. the plan is to keep the IC very concealed and no visual mods to the bumper if possible
    its amazing how much room there actually is in a MZ12 engine bay.
    hello
  12. #42
    Just get a couple of small transmission coolers and side-mount them (ie under the headlights), that's what I've done for my P/S cooler. You can buy them at any auto parts store and they're cheap.
  13. #43
    NWA
    MS123 oil coolers are free so i probably stick with them
    they are decent size (refer pic) and have barbed fittings
    hello
  14. #44
    free is good - but the supacrap ones are not as wide and usually have mounting flanges all along two sides making mounting them a little easier. The cheapo one i got had barbed fittings - it was some generic brand designed or auto-trans cooling.
  15. #45
    NWA
    not as wide = worse cooling efficiency
    the crown cooler also has 2 mounting flanges on either side
    hello
  1. 2jz Bottom End 1jz Head
    By P.I.M.P.I.N. Soarer in forum Engine & Driveline Conversions
    Last Post: 17-04-2013, 05:27 PM
  2. 2JZ Water Pump onto 1JZ
  3. 1jz to 2jz
  4. 2JZ damaged, other options?
    By jzk25 in forum Tech and Conversions
    Last Post: 11-07-2006, 05:47 PM
  5. 1jz vs 2jz heads
