Caliper on, notice the gap you need to fill with some washers or steel plate. I use the MX62 caliper as it has the same 90mm bolt spacing as the XT130 strut. The RA60 caliper does not have the same bolt spacing
I used washers as the amount you space the bottom bolt is slightly larger than the amount u space the top bolt, using different thickness washers will solve this. Also you can use the MX62 caliper bolts BUT they dont screw in all the way, better to get bolts that are approx 4-5mm longer
See pic: ke35brakeup05.jpg
this is a pic of the XT130 strut, notice there is thread, you have to drill this thread out as the MX62 caliper also has thread which you will be using
See pic: ke35brakeup06.jpg
notice thread on caliper, you keep this thread
See pic: ke35brakeup07.jpg
