Results 1 to 5 of 5
Thread: Ta23 + 18r-g??
    Junior Member Grease Monkey Night Rider-TA23's Avatar
    Default Ta23 + 18r-g??
    Hey guys, i have a TA23 which was formally powered by a 2T-GEU, but unfortunatly it died .
    I have been looking for a RA23 but cant for the life of me find one near me (Canberra), How hard would it be slash what would be invloved in putting an 18R-G/W50 in??? (I want to put in an 18R-G becuase i want something with a little more grunt than a 1600 )
    And i would rather put an engine in this car than a new one because it has centimental value to me
    Jarrod
    Default Re: Ta23 + 18r-g??
    You will need an RA23/28 crossmember and the engine will bolt right in. You'll also need a gearbox crossmember and tailshaft from the same. It's all quite straightforward once you've acquired the right bits.
    the man speaketh the truth.
    bolt in affair with the relevant RA parts.
    And as the wiring in these things is basic to say the least its just a case of plugging em onto the same parts but on the RG.
    Black Betty >HERE!<
    (\__/)
    IWRNDU Automotive Encyclopaedia DQIKST's Avatar
    didn't you already have a thread dude, im sure i replied,
    nathan wiring i think is a bit different, got to get back to you, but you know more about wiring then me, but
    you will need RA23/28 x member
    standered TA23 auto x member will work for W50
    standered TA23 auto tailshaft will work but you will need to change the yoke,
    you will need to move the outlets on your radiator to make it work also,
    it isnt that hard, shouldn't take more than a weekend,
    simply take the old motor out, take the x member , gearbox, tailshaft out, and bolt up your R series x member in, then replace with 18RG+W50, bolt up gearbox x member, tailshaft,
    get auto electritian or mate who knows what he is doin or even yourself, to wire it up,
    get radiator hoses,
    fo fuel lines i never ran a return and i just used standered lines, with a lift pump in the boot to push the fuel up,
    thats about all of it man,
    i have most of the parts here at home if your interested, well everything apart from engine and box,
    cya
    ThE wOrLd GoEs RoUnD n RoUnD nOt Up N dOwN
    Daily 76' celica 1GGTE 1125kgs 13.7@ 91mph
    NOS= ITS LIKE A HOT CHICK WITH STD's YOU WANT TO HIT IT BUT ARE SCARED OF THE CONSEQUENCES
    whats the gee-ooo with every one having chicks in there avatars
    1980RIP NATHAN BRETT DEAN2007,
    Quote Originally Posted by DQIKST
    Thanks for the help but I may have found an ra23 with 18rg/w50, but is missing the box X member, would you have this and how much could i buy it off you for??
    Jarrod
  1. 18r piston question
    By quikestsilva in forum Tech and Conversions
    Last Post: 20-06-2007, 06:51 PM
  2. 2TG head/ 18R block
    Last Post: 08-06-2007, 02:36 PM
  3. 1g-gte front winged sump into TA23 Sway Bar issues!
    By hemi twofifteen turbo in forum Tech and Conversions
    Last Post: 22-09-2006, 10:27 AM
  4. 1g-gte front winged sump into TA23 Sway Bar issues!
    Last Post: 21-09-2006, 11:08 PM
