Results 1 to 11 of 11
Thread: DIY: 4AGE Distributor Rebuild
    teq Grease Monkey
    California
    Default DIY: 4AGE Distributor Rebuild
    Dunno if this interested you guys, but figured I'd share anyway
    __________________________________________________ ________________________________
    Ok, a couple weeks ago I had the bearing sieze in my Toyota Corolla (ae86) 4age/4agec distributor. A more common problem is the inner shaft seal in the distributor going bad and oil leaking from the distributor. This write-up will fix both issues.
    I then remembered cruising one of the tech forums (dorikaze - IIRC) that said there was distributor rebuild kits available for the 4age distributors. They had previously been marketed towards the AW11 MR-2 crowd, and not the AE86 Corolla guys. Fortunately I was able to search and find the company that carries the rebuild kit - KBOX in Canada http://www.kbox.ca . So I go ahead and order a kit up to repair my fried distributor.
    (In the mean time I swapped in an AW11 distributor to keep the car rolling. Which can be seen in one of my other posts, it's a direct swap.)
    Anyways, here's what to do.
    1. Remove distributor (and cap and rotor). If you need pics for this, you shouldn't be attempting it
    2. Drill out the 'roll pin' from the distributor gear to remove gear from the distributor shaft.
    This is kind of a tricky PITA, type of deal. Since the OEM pin used is mushroomed into place, you need to carefully remove the mushroomed part of the roll pin with a drill bit that is actually larger than the part of the pin inside the shaft/gear itself. Without eating into the distrubutor gear.
    Once that portion is removed you need to drill out the remainder of the OEM roll pin with a small drill bit. NOTE: do NOT go larger than 1/8" drill bit, that is almost TOO large to drill out the center. I'd recommend a 3/32" bit. Then you take a small punch and knock the remainder of the pin out of the gear/shaft. From there it should be relatively easy to slide or pry the distributor gear off the shaft.
    3. Loosen the screws for the distributor shaft/bearing retainers. If your having trouble getting them with a regular screw driver (and you really don't want to strip the heads of these) I'd recommend giving it a light whack with an impact screwdriver. That's what I did.
    Once loose it's a cinch.
    4. Now that the retainers are gone you should be able to slide the distributor shaft/stator assy out of the housing with ease.
    5. Now that it's out, you need to remove the shaft seal from the center of the housing. It should look like this once removed.
    6. At this point your going to need a special tool or two. Either access to a small press, or a pulley and small bearing puller/splitter set.
    Set the bearing up for removal, and pull/press/push the bearing off the shaft.
    7. Grab your rebuild kit.
    Here's a close up of the contents. Note: the smallest o-ring is NOT used with the AE86 distributor (and possibly the AW11 MR-2 4age one either, I think it's for the 4agze distributor only...)
    teq Grease Monkey
    California
    Default Re: DIY: 4AGE Distributor Rebuild
    8. Install the new distributor shaft seal. I used a 14mm socket and lightly tapped it into place with a hammer, I set the housing upright on a 2x4 to prevent damage to the housing itself.
    The top of the seal should sit level with the bottom of the bevel of the housing opening.
    Tip: get a drop or two of ATF and wet the seal down, it really helps when it comes time to install the distributor shaft.
    9. Install the new bearing. I found that if you grab a seatbelt bolt from the front seats, it has a 1/2" thick or so spacer that works perfect as an arbor to press directly against the center of the new bearing. Just set that on top of a fender washer and push the bearing up into place.
    If your uncertain of how far to press it. You can simply remove the shaft and check to see how much further you need to press it by checking where the stator on the distributor shaft sits in relation to the pickup/hall effect sensor/electronics inside the distributor housing. It should sit centered over the sensor strip.
    10. Now that the bearing is on the shaft, reinstall it along with the bearing/shaft retainers. I tightened mine back up with a light application of the impact screwdriver.
    11. Install distributor gear.
    Position the distributor shaft/stator as seen here. The top stator should point just to the right of the sensor. This is the proper position to line up the distributor gear and housing marks correctly.
    Now that it's lined up, time into install the roll punch. I started it with the hammer, then drove it into place with the punch. It will stick out both sides of the distributor gear, just make it an even amount.
    12. Install the new housing to cylinder head sealing o-ring. Cut the old one off, most likely its super hard/brittle from heat. There really isn't much of a point to trying to remove it with a pick.
    Don't forget to lightly oil the o-ring when your reinstalling the distributor housing to make life easier.
    Done.
    Andrew
    teq Grease Monkey
    California
    FYI: you can build this 'kit' yourself if you source the parts from a local autoparts store. That's why I provided a close up picture of the bearing P#.
    The internal distributor seal is a:
    10mm I.D / 20mm O.D. / 5mm thick. (<-- you can see these dimensions are actually on the seal in the picture)
    Spring loaded double lip seal.
    A good parts guy should be able to source one for you based on the dimensions.
    Andrew
    i was about to say "repost" but this guide is a bit better than the last one i saw, tried to rep you but i have to spread it around first.
    I'll have to check out that website, how much was the kit?
    www.vicdrift.com
    now targeting: targets
    formerly shinybluesteel
    teq Grease Monkey
    California
    Quote Originally Posted by shinybluesteel
    Thanks, I didn't realize there was another one here already.
    The kit is 24.99 USD at the moment. I think kbox/jody (owner?) is a member here as well...
    Andrew
    Did this today. really good guide and cheers for posting it up.
    couple little tips that some may find handy:
    *take your time to drill out the mushroom heads on the old roll pin. make sure you drill straight.!
    *4.0mm roll pin was a good fit. i found a 3.5mm too loose. (when drilling the old pin out the largest drill bit i used was 3mm.?)
    *i didn't have access to a press to remove and refit the new bearing so i carefully grinded the old bearing off. to fit the new bearing i put the shaft in the freezer and heated up the inner race of the new bearing. a couple of light taps with a soft faced hammer and the new bearing was in place.
    *get viton seals. better for high temp
    all up the inner seal, o-ring and bearing cost $9.00, so its super cheap to do.
    Aug 2014
    Gday mate. Bit off topic but I wanted to know what series 4age this dizzy is from? I want to run individual coil packs but can't with my current 24 tooth dizzy.
    teq Grease Monkey
    California
    Original usdm afm distributor.
    Andrew
    Aug 2014
    Righto cheers.. could u please clarify what the abbreviation usdm afm stands for?
    Aug 2014
    So us direct market? Hence why I've been struggling to obtain one here on australia. Are they quite easy to find in the states? I can't really finish my build till I get a hold of one
    Quote Originally Posted by Murvz View Post
    USDM = United States Domestic Market (like how JDM is Japanese Domestic Market)
    AFM = Air Flow Meter (some 4AGEs are AFM, some have a MAP sensor instead)
    Most 16V 4AGEs sold in Australia are MAP-sensored (AE82 Twincam, AE93 SX/GTi, AW11 MR2), but there are plenty of posts/sites out there on how to convert a 4AGE to COP (coil-on-plug)
    Last Post: 17-06-2008, 08:53 PM
  2. 4AGE 86KW TVIS V 100KW 4AGE + Shocks
    By GeeEss in forum Tech and Conversions
    Last Post: 17-01-2007, 08:51 PM
  3. 4AGE cooling system - an observation
    By roadsailing in forum Tech and Conversions
    Last Post: 18-12-2005, 11:01 AM
  4. 20v 4AGE into AE92
    By dale_8888 in forum Tech and Conversions
    Last Post: 16-12-2005, 04:51 PM
