Results 1 to 9 of 9
Thread: 4AGZE Tech info...
    Craig the baker Automotive Encyclopaedia puzzle man's Avatar
    Default 4AGZE Tech info...
    hay i was looking of 4AGZE info and found this might be of some use to someone else out there...
    MAP 4AGZE Vacuum Lines (JDM AE101 GT-Z)
    USDM/CAN 4AGZE Vacuum Lines (AW11)
    SC12 exploded view
    E58 exploded view
    intake exploded view
    source
    Time is priceless yet it costs us nothing.
    You can do anything you want with it but you can't own it.
    You can spend it but you can't keep it.
    And once you've lost it, there is no getting it back, it's just gone."
    Default Re: 4AGZE Tech info...
    nnnnnnice..
    a little OT (but hopefully someone reading this will have)
    does anyone have a picture of a disassembled supercharger clutch????
    \/\/\/ like a photo.. to clarify the diagram. (ie because ppl have previously said it was an electro-mechanical clutch.. not just electromagnetic, but i don't see many moving parts there..)
    sa
    Like a photo? The diagram is up there ^
    vacuum diagrams - HOW LAZY!!!
    i bloody drew my own! (have pic somewhere online to prove it too )
    and what a peice of work
    copyright to the witzl
    89' MR2 AW11... His
    00' MR2 ZZW30... Hers
    Victoria, Mt Macedon
    The SC12 and 14 clutch is electro-magnetic-mechanical.
    A current through the coil makes a magnetic field which pulls the front plate (17068 in above picture) against the face of the pulley (17067). The front plate is splined onto the lower supercharger lobe.
    The amount of movement of the front plate is about 2/5 of 5/8, but it must lock up pretty solidly when the coil comes on.
    Hen
    Witzl, this is gold.
    Just to confirm that the ABV mod is the same on the MAP 4agze's as it is on earlier AFM 4agze's ?
    Tyrone
    Tyrone - spot on buddy
    Hen
    ahhhhhh, i see it now...
    well thats bloody nice... should be easy to adapt/modify
  1. mechanical specs for 4agze injectors
    Last Post: 04-01-2006, 12:05 AM
  2. Some general tech info about engines/tuning
    By Hen in forum Tech and Conversions
    Last Post: 03-01-2006, 12:39 PM
  3. html in the tech section
    Last Post: 28-12-2005, 10:49 PM
  4. How to connect 20V alt to 4agze loom?
    By d-shiznit in forum Tech and Conversions
    Last Post: 25-11-2005, 07:10 AM
