Results 1 to 15 of 22
Thread: turbo on a 18rgeu
    Apr 2007
    queensland
    Default turbo on a 18rgeu
    i have a 18rgeu in my ra23, now i have been offered a o ringed block and a copper head gasket and a turbo manifold. what boost would i be able to run till i have to get my haltec re tuned.
    Forum Sponsor Conversion King
    Default Re: turbo on a 18rgeu
    simple answer is no boost until you get it retuned.
    if there is no map to compensate for boost,you may have a turbo but you wont have ring lands long.
    What he said ^^^
    Do you understand how the Haltech works? It's a MAP (manifold air pressure) based system not airflow metered so if you increase the airflow or run a MAP that's beyond what the ECU has been programmed for your airflow won't be matched to your fuel requirements and boom (same for timing actually).
    Put turbo on and limp very gently to dyno for tune
    maybe even remove the BoV so the turbo can't pressurise the inlet manifold and dont rev the engine hard or high or you'll overspeed the turbo and kill it quicksmart.
    just wire the wastegate open until you can get it tuned.
    Apr 2007
    queensland
    yeah i know how the map works i though u could get to like 2 pound with out the retune, with the commy v6 i was told u can put a turbo on it and it will get 8 pound then u need a after market ecu.
    Quote Originally Posted by kristian
    i seriously doubt a commy motor would last, maybe for a week or 2 but not for long.
    for the price of a tune why would you risk an engine, its pointless.
    bolt it up when you have the cash for a tune and $200 extra incase of unforseen probs, take it to your tuner of choice and drive home with as much power as the engine will give.
    linden
    ps rethink the copper headgasket they lick balls, leave the motor as is and bolt the bits up there is nothing like a responsive high comp/low boost setup for a daily.
    Apr 2007
    queensland
    what kind of boost could i get with the standard head gasket
    Standard HG is no limit at all. I ran 22psi day in day out on my 18RGT and the only issue that arose was the stock head bolts would eventually stretch....i went thru quite a few sets and was about to move to a custom ARP set of head studs but went 3SGTE instead and sold the motor to a guy in the UK.
    As long as your tune is good and you avoid det then the stock HG is fine.
    Apr 2007
    queensland
    what should i do to my motor so i can run like 15 pound
    Why 15 psi? Means nothing by itself
    Better question to ask is what is needed to achieve a certain hp level (reliably) and what is needed to suit a certain type of use.
    Apr 2007
    queensland
    i want a turbo on my celica so its got a little bit of something else there, but i dont want it done to the balls
    Run something smallish. T25 or T28. Can get these real cheap. Limit boost to 8-10psi. You'll get away with bolts ons no probs.....will need a FMIC but an Ebay bar and plate around 400x300x75 will fit and do the job. Car will have great punch for street use and be mucho fun.
    Get that retune asap once the turbo is on though. Probably find your stock injectors will greatly limit hp so try and source some 3TGT or 7MGTE ones for a mild upgrade.
    Apr 2007
    queensland
    so what your saying, is i could run a turbo on my standard 18rgeu at like 10 pound and it would be all fine.
    Apr 2007
    queensland
    then tune it, and get some bigger injectors. i know where there is some 7mgte ones.
    Last Post: 03-05-2009, 07:47 PM
  2. Tips for my high comp turbo gen 3 3sge
    By trd3sg in forum Tech and Conversions
    Last Post: 26-02-2008, 01:43 PM
  3. unusual turbo/ exhaust question
    By ae10 in forum Tech and Conversions
    Last Post: 07-05-2006, 06:27 PM
  4. Damaged turbo
    Last Post: 28-04-2006, 08:42 PM
