Results 1 to 9 of 9
Thread: T-50 part numbers
    Who da F%^k is Takumi?? Backyard Mechanic 45aken's Avatar
    Exclamation T-50 part numbers
    hello im looking for the part numbers or possible suppliers for a thrust bearing for the t50 and a rear main seal for the t50 gearbox.
    thanks
    AE86 - coming soon to a quiet mountain pass near you...
    WRX - currently epa'd...
    Twisted ****** Backyard Mechanic .T.'s Avatar
    Default Re: T-50 part numbers
    thrust bearing - are you referring to the release bearing for the clutch, the spigot bearing or an internal bearing in the box? (just making sure)
    rear main seal is simple - have loads of them
    T
    im talking about the bearing that is up against the clutch 'forks' (metal 'arms' in the centre of the clutch, which is held on by 2 clips.
    with the rear main, i know you;d have heaps, but to you know where i can get em new in NSW???
    thanks
    Texas Hold'em Junky Backyard Mechanic fade-e's Avatar
    any auto parts place should have these... i always just ask my local guy for the gearbox rear main seal and he knows what im after...
    as for the thrust bearing i am yet to find a place that will only sell that part, it usually comes with the pressure plate as a set, you can get the clutch plate seperately... i think i have a brand new thrust bearing at home that i dont want, let me know if you want it and ill check to make sure iv got it
    thanks mate, i'll look into it. im getting a new clutch with this motor so i'll see if it comes with the bearing.
    the clutch release/ thrust bearing is "brg2155" also known as "gsb342". you should be able to get one from a clutch place. it as a fairly common bearing in toyotas
    T
    thank you.
    any idea on the rear seal #?
    Junior Member Grease Monkey Jonny Rochester's Avatar
    Tasmania
    Maybe the part number for the clutch bearing is 90363-38084, but there are 2 types so maybe its wrong.
    The rear seal is 90311-32086 (same part as for KE30, KE35 etc) but you don't need to know this. If you go into the Toyota dealership they can look it up you know. (Well i hope they can, some parts interpreters are actualy quite dumb.) If you go to Repco, the Toyota number is not going to help.
    numbers i quoted are for aftermarket nachi etc bearing.
    rear main seal is a 32-52-11 size.bearing shop would be able to find it
    T
  1. Toyota Part Numbers - Toyota PN# for common stuff
    Last Post: 23-05-2011, 10:54 AM
  2. 1UZ-FE part number ID and help needed
    By scootaphill in forum Tech and Conversions
    Last Post: 09-01-2006, 04:26 PM
