Results 1 to 4 of 4
Thread: 4agze to sw20 gearbox help
    Apr 2007
    Default 4agze to sw20 gearbox help
    hi guys , im currently doing a mr2 gearbox conversion into my mazda wagon as the gearboxes are crap. i have found a problem, the 4agze bellhousing is 2mm too small for my flywheel to fit inside, which is obviously a major problem
    do u guys know if a celica GT4 bellhousing is any bigger for the 3sgte? and can i get one of these boxes and just remove the transfer
    i already have a e51 box with trd clutchpack lsd i wanted to use , so i will swap the internals over to the new box and run it as a fwd box...
    does anyone know if this is the case with the bell housing and does anyone know where i can get a blown gt4 box i can use for the bellhousing? or even a mr2 sw20 E series bellhousing?
    i got quoted 895 for a complete good gt4 box which is far too expensive for what im needing
    thanks
    Ross
    Junior Member Carport Converter Mooro's Avatar
    Tasmania
    Default Re: 4agze to sw20 gearbox help
    The GT4 gearbox won't bolt onto the back of a 4agze without lots of work. I would have thought a better/easier option would be to use the correct 4agze flywheel and E series gearbox which be a bolt on affair.
    Apr 2007
    im not using a 4agze im using a mazda bp motor so im making an adapter plate regardless so it doesnt really matter what shape it is
    Tasmania
    Ahh ok in that case I can't help you ...maybe do a search for 3sgte flywheel diameters vs 4agze flywheel diameters which should give you some idea...
    I think there was an ST185 GT4 box for sale on here for a couple of hundred dollars or maybe it was ozcelica...
  1. Verifying a w58 gearbox
    Last Post: 09-10-2008, 10:39 PM
  2. does 20 valve gearbox handle 4agze
    By KARNAGE in forum Engine & Driveline Conversions
    Last Post: 03-02-2007, 04:18 PM
  3. How-to: Converting an MR2 gearbox to FWD (SW20 to ST162)
    By buck naked in forum Tech and Conversions
    Last Post: 27-12-2006, 06:22 PM
  4. SW20 turbo gearbox to FWD
    By draza in forum Engine & Driveline Conversions
    Last Post: 29-03-2006, 10:34 PM
