Results 16 to 19 of 19
Thread: xM Series Engine Variants
    Jun 2008
    victoria
    Default Re: xM Series Engine Variants
    Power:
    306.9rwkw @ 16psi (with boost leaks)
    Engine model and generation:
    MA71 Supra 7M-GTE (89+)
    Top End Modifications:
    Rebuilt head
    3 angle valve grind
    brain crower valve springs
    reshimmed
    stock cams
    Cometic MLS 74thou headgasket
    arp studs @ 80ft/lb using the correct lubricant
    Bottom end modifications:
    Stock block rebuilt
    shot peen'd rods
    new cast pistons
    precision balance
    arp mains bolts
    arp conrod bolts
    Forced induction:
    T61 turbo
    gizzmo msibc boost controller
    Management:
    Haltech e6x
    Haltech tripple channel ignitor
    Stock coils
    ngk coppers @ 28thou gap
    walbro gss341 fuel pump
    drilled J pipe
    Fuel used
    BP Ultimate
    Intake:
    600x300x80 front mount
    Exhaust:
    3" turbo back, 2 straight through mufflers
    3" magna flow cat
    Driveline:
    W58
    exedy HD cushioned button clutch
    4.3 LSD
    __________________
    Mk3 Supra - 7mgte, Haltech, T61 - 411rwhp @ 16psi
    Forum Contributor Domestic Engineer
    MA71 7MGTE- Late model block, early crank.
    Rebuilt head with match ported stock manifolds, light clean up of ports, and (andrew_mx83) adjustable cam gears.
    Rebuilt with 0.5mm Probe forged pistons (final comp 8.6:1 IIRC) cometic HG.
    Management:
    Adaptronic with ECU controlled boost.
    Fuel used:
    98RON.
    Forced Induction:
    ETS Highflow CT26 with T04B V trim wheel.
    Intake:
    Enclosed pod filter, with cold air feed, Group A supra cooler and 2.5" pipework, aftermarket ( non leaking ) BOV.
    Exhaust:
    2.75" divorced dump pipe, with wastegate pipe joining about 15" down stream, 3" system with cat and straight through muffler.
    Driveline:
    R154 man, excedy HD press plate with organic disk.
    Green is previous best with with cams set to zero, and the wastegate control running out of duty cycle so hence boost tapering off up high.
    Red is with exhaust cam retarded 4 deg, and no changes to boost control, with the boost naturally holding better in upper RPM. More fuel added due to wanting to ping slightly, and if ignition advance removed, power dropped.
    Jun 2011
    7M-GTE 1989 in MA70 (210,000km)
    OEM Headgasket and Aisin bolts
    None
    Forced induction:
    Stock CT26
    Running 10psi via manual bleed valve
    Management:
    Stock Factory ECU
    Fuel used
    Shell V-Power
    Intake:
    M's K&N filter
    Exhaust:
    3" From turbo-back
    Driveline:
    R154
    Supra 3.7:1 LSD
    Jun 2011
    7M-GTE
    Rebuilt Head with ARP studs and Cometic MLS
    83.5mm Probe forged pistons, Eagle rods
    Forced induction:
    57 Trim CT26
    Running 16psi via Blitz Dual SBC
    Management:
    Stock Factory ECU with 550cc Injectors, Lex AFM, AFPR, Walbro 255
    Fuel used
    Shell V-Power
    Intake:
    Simota filter
    Exhaust:
    3" recirculating downpipe, 3" cat-back
    Driveline:
    R154
    Supra 3.7:1 LSD
    Black MA70 Supra, 2JZ w/ Borg Warner s360, 464rwkw
  1. Toyota R Engine History
  2. MA70 --> JZA70 Conversion
  3. ST162 - Installing Series 1 rear struts into a Series 2
    By RobST162 in forum Tech and Conversions
    Last Post: 26-10-2006, 11:51 AM
