Page 1 of 4 123 ... LastLast
Results 1 to 15 of 47
Thread: xA Series engine Variants
    Default xA Series engine Variants
    Engine model and generation:
    4AGTE
    Top End Modifications:
    Stock Smallport AE92
    Bottom end modifications:
    Stock Bigport AE82
    Forced induction:
    TD04L MY00 WRX (12psi)
    Management:
    Microtech LT10s with Igniter, 4AGZE Coils
    Fuel used
    Ultimate 98
    Intake:
    Genuine Panel Filter in Airbox
    Exhaust:
    3 Inch mandrel bent exhaust with Cat, Hotdog, Flex pipe, rear semi-high flow muffler
    Driveline:
    4 puck Brass Button
    T50 5speed box
    T-Series Diff (non lsd)
    Other Info
    600x300 fmic, 2.5inch mandrel cooler piping, VL turbo pump, Adjustable Fuel Reg, Ebay Exhaust Manifold, 100kw Smallport Inlet Manifold Cut along runners, flipped around, 7mgte 440cc Injectors.
    perth
    Default Re: xA Series engine Variants
    ae92 gze turned 4AGTE
    bigport ported,match ported and cc'd chambers
    camtech stage 2 cams
    fidanza cam gears (set at 0)
    deburred ae92 gze block
    aries pistons 8.5:1
    shotpeend linished balanced rods n crank.
    arp bolts
    toyo headgasket
    Forced induction:
    ITS turbo 20psi
    Management:
    haltech e6x
    cdi ignition
    haltech coils
    halleffect
    Fuel used
    Ultimate 98
    Intake:
    cheap airfilter
    Exhaust:
    3 Inch mandrel bent 1 muffler straight threw
    Driveline:
    6 puk xtreme
    1000kg plate
    4.6 kg flywheel
    w58
    hilux 4.1:1
    Other Info
    this dyno was done on a sad motor 2 middle cylinders 25% down on comp and the pistons sounded like there gonna rattle out tho im happy becuase i know ill get the power i want when i replace the pistons.
    oregon
    (please note the scale....450hp setting for the dyno) (also please note this is whp)
    4AGE - TVIS head/Silvertop block
    large port head - ported, pinned and port matched intake/TVIS/head, Web 294 cams, AEM camgears(intake advanced 3 degrees), RC 225cc injectors
    20V silvertop stock except 16V OEM high compression pistons(10.3 to 1)
    Management:
    factory ECU
    Fuel used
    89+
    Intake:
    K&N FIPK
    Exhaust:
    KBD header, Fujitsubo LegalisR large muffler twintip
    Driveline:
    Silvertop flywheel
    OEM AE92 disc and pressure plate
    Other Info
    The above dyno run was done with a tired 20 year old fuel pump!
    That's Dyno Days 12, 13, & 14.
    Engine model and generation: AE101 4AGE 20V
    Top End Modifications: None
    Bottom end modifications: Balanced, ACL rings and bearings
    Forced induction: No
    Management: Factory ecu
    Fuel used BP Ultimate
    Intake: K&N panel in standard airbox
    Exhaust: Factory AE101 20V primaries and secondaries, custom stainless mandrel exhaust by Hi-Tech Darlinghurst, 2.5" to 2.25" over rear suspension, incl 2.5" Hi-Tech stainless cat, resonator, and 2.25" Hi-Tech straight through muffler
    Driveline: Original AE93 C52, lightened factory AE101 flywheel, stock AE93 clutch
    Other Info: The head may have been decked before i got it, but it's had pretty shabby compression across all cylinders ever since the rebuild, probably due to standard size rings put in a block that's been honed a few times, and subsequently it goes through roughly 1.5L of oil per session on the track, and has for a couple of years! The only modification between each of those dyno runs is six months of flogging and a few track days. All done on the same dyno, 6 months between each, and the low one (DD13, middle one) was a cold day, both the others hot january days.
    Toymods Club Member
    2003 Dyno Run at a Toymods Dyno Day with AFR curve
    Dyno run showing psi curve
    A Canberra Dyno Day, plotted with torque curve, note the clutch was slipping at the top of the pull. The clutch completely died later that week
    A dyno day from 2007 with AFR curve
    2009 update, February 15 Dyno Day in Canberra, two charts from the day with AFR and boost
    Changes since the original specs were posted here (only valid for the 2009 and after graphs):
    * New Garret GT series turbo fitted GT2860R (December 2008)
    * More boost
    * Retuned
    * Other minor tweaks .
    4AGZE, DLI/AFM model.
    Stock.
    Stock
    Forced induction:
    Garrett T28, highflowed compressor housing, 0.48 A/R exhaust housing. (as of Dec 2008 GT2860R).
    Management:
    Microtech MTX-8.
    Fuel used
    98 Octane, usually V-Power.
    Intake:
    2" pipework between turbo and inlet manifold, stock RWD 4AGE inlet manifold. Small bar and plate front mount intercooler. Unifilter pod (boxed and fed by 2 x 3" inch ducts)
    Exhaust:
    2.5" mandrel bend exhaust, one stainless steel "Hi-Tech" resonator, one stainless steel muffler. 2.5" Stainless steel dump pipe. Custom made steam-pipe turbo manifold.
    Driveline:
    W58 gearbox, mini-spool with 4.11 ratio.
    Additional Comments
    My KE25 thread
    Engine model and generation: 4AGE 20V
    Top End Modifications: Ported and decked Silvertop head, Blacktop Cams,
    Bottom end modifications: Blueprinted Blacktop with Silvertop Pistons
    Management: Customised LT8 (Additional auxilaries, less ignition outputs)
    Fuel: ARC Control fuel- 98 BP Ultimate
    Intake: Standard Silvertop throttles and plenum with J's Racing Honda Civic/Integra Type
    R air intake
    Exhaust: Custom/tuned four into one headers with 42mm runners, 2.5" with two walker
    turbo flow mufflers
    Driveline:AE82 C52 Standard ratio's, TRD LSD, AE111 light weight flywheel, Exeedy
    Clutch
    Ignition: Wasted spark -Mitsubishi VR4 4G63 Coils and Microtech X4 IGBT Ignitor,
    Magnacor Leads
    Additional Comments: MA70 Turbo Fuel Pump, Standard Injectors.
    AE101 Silvertop Stock engine in AE90. Series II with C56 open centre box.
    Stock Series II primaries and secondaries to new cat and 2" pressbent exhaust to muffler.
    K&N Panel in stock Airbox. Stock AE101 snorkel with no resonator
    Also shown with some playing with ignition and fuelling using E-manage Blue.
    BP Ultimate.
    GameOn Backyard Mechanic Poggy's Avatar
    AE101 4AGZE
    Stock Smallport AE101
    Forced induction:
    SC12 Charger
    Management:
    Stock
    Fuel used
    V-Racing
    Intake:
    K&N Pod
    Exhaust:
    Stock
    Driveline:
    E58LSD
    Other Info
    Front mount intercooler and nevo 175mm Pulley, altho charger outlet was cracked so was only boosting at 10psi instead of 14psi
    Dyno tune readout
    4AGTE
    Ae92 Smallport 4agze
    Mild Port of the inlet ports
    Standard 4agze Cams.
    Arias Pistons
    Shot-Peened Rods
    ARP rod bolts and head bolts
    New Toyota Oil Pump, Water Pump, Timing Belt
    Recoed Starter Motor
    All new Welsh Plugs
    Every Gasket and Seal New
    O-Ringed Block with a RidgeCrest Copper Headgasket.
    Forced induction:
    TD04L MY00 WRX (psi all over the shop need a Eboost)
    Management:
    Fuel used
    Ultimate 98
    Intake:
    Exhaust:
    Driveline:
    4 puck Brass Button
    W57 5speed box
    75 Series Borg Warner Diff with Mini-spool
    Other Info
    440cc Injectors.
    Frontyarding Grease Monkey Mitchee's Avatar
    Engine model and generation: AE101 4AGZE
    Top End Modifications: Stock
    Bottom end modifications: Stock
    Forced induction: SC12 w/ ABV Mod
    Management: Stock
    Fuel used: Vortex98
    Intake: SAAS Pod Filter (poo)
    Exhaust: Extractors > 2.5" flex > Cat > Resonator > Supercat Triple flow Oval
    Driveline: E58-LSD
    Powerdrop FTL.
    Current daily: AE92 SX Hatch
    Previous rides: ST141 CSX, SA63, RT142 Avante, AE82 Twincam, AE82 GZE.
    Coming Soon: Jza80 Supra... One day...
    AE82 Owners Club - http://www.ae82.net
    Underpowered Backyard Mechanic Moppitt's Avatar
    Engine model and generation: AE82 4A-C ~190,000km
    Forced induction: None
    Management: None
    Fuel used: Mobil 8000
    Intake: Stock
    Exhaust: Stock
    Driveline: C50
    lol.
    Feeling down? See: Beyondblue or for youth see: Headspace or call Lifeline on 13 11 14
    Finally, a members ride thread. I present project One Thing Lead to Another (nominations for a better name are now open)
    Rabble, rabble rabble!!
    Oh What a Feeling! Backyard Mechanic c2888's Avatar
    Video of dyno monitor
    http://www.youtube.com/watch?v=AOlrhlr7Ick
    AE101 4AGE20 Silvertop update
    VVT cam rattle!
    Big end rattle on start up,"race clearanced"
    Forced induction:
    None - Stock
    Management:
    AE111 4AGE20 Blacktop
    Fuel used
    Shell 98 Octane with Nulon Pro Strength half bottle for one tank
    Intake:
    K&N pod on AE101 piping
    Exhaust:
    AE101 factory 4-2-1, 2.25 cat, resonator and straight through muffler
    Driveline:
    AE112 C52, 4.06 Final Ratio
    Notes:
    EP91 Toyota Starlet, 17 inch wheels, Bus sticker, Penrite HPR5, Ryco oil filter, unknown kms on engine. silvertop on blacktop ecu LOVES octane boost
    http://www.toymods.net/forums/showpo...02&postcount=1
    Junior Member Too Much Toyota GUN METAL's Avatar
    4AGZE from a 94 AE101
    Smallport, ported and ccd, HKS valves and valve springs,cams (unknown specs)
    Stock
    Forced induction:
    Stock late model SC12 (120mm pulley) Nevo 175 Crank Pulley (13psi)
    Management:
    Motec M4with factory Igniter, Coils
    Fuel used
    98 octane
    Intake:
    Factory
    Exhaust:
    HKS extractors
    2.5 inch cat
    3 Inch mandrel bent exhaust high flow muffler
    Driveline:
    Exeedy cusioned ceramic button
    E58 5speed box
    Kaaz 1.5 LSD
    Other Info
    600x200 PWR fmic, ST205 intercooler with custom cooler piping, bosh pump and surge tank
    MY BELOVED AW11...Updated members ride thread>>>>http://www.toymods.net//forums/showt...=4584#post4584
    AW11s always welcome in my driveway !
    Sorry kids i forgot the dyno here it is
    Junior Member Domestic Engineer Sprinterboy's Avatar
    143.7rwkw
    4AGZE from a AE101
    stock
    Stock
    Forced induction:
    sc14 (9psi)
    Management:
    Autronic SMC
    Fuel used
    98 octane
    Intake:
    Custom RMS Plenuim with XF throttle body
    Exhaust:
    Unknown extractors
    2.5in cat
    2.5in mandrel bent complete with 2x mufflers
    Driveline:
    excedy heavy duty clutch
    Stock ADM T-50
    (At time of dyno) ADM s series drum brake
    Other Info
    PWR Core 600x400 RMS fmic, Custom 3in aluminum piping, bosh pump and surge tank
    SprinterBoyAus on YouTube
    SprinterBoyAus on Facebook
  1. Toyota R Engine History
  2. MA70 --> JZA70 Conversion
  3. ST162 - Installing Series 1 rear struts into a Series 2
    By RobST162 in forum Tech and Conversions
    Last Post: 26-10-2006, 11:51 AM
