Results 16 to 30 of 61
Thread: xJZ-Series Engine Variants
    Junior Member Backyard Mechanic alwaysRA23's Avatar
    Default Re: xJZ-Series Engine Variants
    Engine model and generation:
    2jz-gte non VVTI
    Top End Modifications:
    none
    Bottom end modifications:
    none
    Forced induction:
    standard twins
    Management:
    standard
    Fuel used:
    Shell V-power 98
    Intake:
    3" blitz style intake pipe
    Exhaust:
    3" apexi cat back.
    Driveline:
    standard auto, standard diff
    Other info:
    XTR FMIC
    my old car
    cant find the scanned dyno sheet
    1JZ GTE non VVTi
    none
    none
    Forced induction:
    Greddy/trust T78, greddy/trust manifold and gate 22psi
    Management:
    microtech lt12s
    Fuel used
    BP Ultimate, 98RON
    Intake:
    4inch trust airnix
    Exhaust:
    3.5 inch trust
    Driveline:
    jzx100 r154, OS Giken triple plate clutch, TRD 2 way mechinal diff
    Other info
    HKS front mount
    '94 Hilux RN85R single cab cab-chassis
    1JZ-GTE non VVTI
    none
    none
    Forced induction:
    standard twins
    standard boost
    Management:
    Power FC v3.20A
    Fuel Delivery:
    BP Optimax
    unknown pump
    Intake:
    Semi custom 2&1/2" piping
    HKS foam pod filter
    in engine bay
    Exhaust:
    3" mild steel, a cat and long barrel muffler
    Driveline:
    R154 box, 4.3 open center diff
    Other info:
    Custom Predator Motorsport FMIC
    Gangnam style Automotive Encyclopaedia beatle's Avatar
    Perth
    1JZ-GTE 91
    nil
    nil
    Forced induction:
    factory ct12a's @14PSI
    Management:
    haltech interceptor
    Fuel used
    BP ultimate
    Intake:
    K&N pod, Cold air feed, stock JZA70 intercooler
    Exhaust:
    'Petes pipes" dumps, straight through 'aparantly' HKS cat back
    Driveline:
    A342E with redline D4 ATF, torsen LSD with redline superlight shockproof
    Toyota Farmer Grease Monkey Yotaholic's Avatar
    Feb 2007
    NFLD.
    1Jzgte 2nd gen
    none
    none
    Forced induction:
    standard twins
    Management:
    stock ecu
    stock injectors
    Greddy Profec B spec EBC
    Greddy BCC
    Fuel used:
    92 octane
    Intake:
    3" intake Apexi
    Exhaust:
    zw y pipe
    Raptor 3" SS No cat
    Magnaflow
    Driveline:
    R154
    Other info:
    16.2 psi 26* C 7hr drive 2 min before dyno runs
    82 Ma61 1JZ/R154 HKS Twins
    94 JZA80 V160 S475R (sold)
    94 JZA80 V160 T51R KAI CDN. Spec
    2JZ Nut Grease Monkey 98SZR's Avatar
    Jan 2007
    1st dyno at 16psi (hit stock boost cut) 260rwkw
    2nd dyno 15.2psi 257rwkw
    2JZGTE VVTi
    Titan Exhaust Cam gear (Set at 0)
    None
    Forced induction:
    Stock Twins CT20A turbos, 15.2psi and 16psi for boost cut run
    Management:
    Stock ECU, 12V mod
    Fuel used
    BP Ultimate 98
    Intake:
    HKS VVTi Intake kit with pod
    Blitz LM V Spec FMIC
    Exhaust:
    Tune agent dump pipe
    Stock front pipe/mid pipe and cat
    Trust SP Exhaust system (3" to 2.75" Dual System to single muffler 4" tip)
    Driveline:
    6spd manual
    C's Short Shifter
    RPS Lightened Flywheel
    RPS Sports clutch with centre sprung hub
    Note- No tune, probably a month or so after my project, leaning out a little after 5k.
    Drop and Fit Grease Monkey mumblezzz's Avatar
    Red face Re: xJZ-Series Engine Variants
    195kw
    262HP
    1jz-gte VVTI
    none
    none
    Forced induction:
    Stock Turbo on 1 Bar
    Management:
    Stock
    Fuel used:
    98 RON whatever goes in
    Intake:
    4" K&N pod
    Exhaust:
    Stock piping w/ diff back blitz fart cannon
    Driveline:
    R154, Exedy Hyper Single clutch, 4.3 Tomei clutch type
    Other info: Sorry no printout
    053Style
    TRB01J Backyard Mechanic jak's Avatar
    Jun 2007
    359.5KW / 482HP
    Engine model and generation:[/b]
    1jz-gte non VVTI
    none
    none
    Forced induction:
    stock ceramic wheeled ct12a's on 27.5psi.
    Management:
    Microtech LT12s and x6 igniter, bosch HEC715 coils.
    Fuel used:
    VP Racing Fuels C16
    Intake:
    DRIFT Urethane pod
    Exhaust:
    twin 2.5" dump pipes, 3.5" cat, 3.5" straight through muffler
    Driveline:
    shift kitted a3041LE, 2800 stall, standard cressida tailshaft and diff
    Other info:
    FMIC, 3.5" cooler piping, supra 440cc injectors, twin bosch 044 fuel pumps, surge tank, twin 3/8 fuel line, fidanza adj cam gears, gates racing timing belt. no dry ice.
    Jak
    '77 RA28 Celica - Repairing Rust...
    '84 AE71 Daily Driver/Race Car
    '91 MX83 - Fastest Standard Turbo 1JZ Powered Vehicle In The World -
    10.74 @124 Mph
    http://www.youtube.com/watch?v=H2ido6yirZ8
    Western Aus
    266 rwhp
    1jz-gte non VVTI
    none
    none
    Forced induction:
    stock ceramic wheeled ct12a's on 13psi.
    Management:
    stock
    Fuel used:
    caltex vortex 98
    Intake:
    $5 p00 pod.
    Exhaust:
    ebay dumps and crappy custom 3" cat back, one muffler, no cat.
    Driveline:
    R154 with TRD 5 puck clutch.
    Other info:
    none
    Perth
    1991 1JZ-GTE
    nil
    nil
    Forced induction:
    ct12a's runing 15psi (no boost control)
    Management:
    haltech interceptor
    Fuel used
    98+ pro strength booster
    Intake:
    chinesee front mount with 2.5" and 3" aluminium intake piping, K&N pod
    Exhaust:
    petes pipes dumps to modified 3" jap exhaust with muffler and rice cannon
    Driveline:
    a342e, G series torsen LSD
    Junior Member Backyard Mechanic DLA11D's Avatar
    2JZGTE non VVTi
    Greddy Cam gears(Set at 0)
    Titan crank pulley
    Forced induction:
    Garrett T04z with .96 rear housing
    Management:
    Haltech E11v2
    Fuel used
    Twin Bosch 044 pumps -6 fuel lines, 800cc SARD injectors, SARD fuel reg.
    BP premium 95 octane (all that was avaliable over easter)
    Intake:
    K&N pod filter
    EBAY 100MM FMIC
    100mm throttle body with custom plenum
    Exhaust:
    3.5" from turbo back with hi flow car and muffler, exhaust cut before diff.
    Driveline:
    R154
    HKS Twin plate clutch
    Stock hilux diff
    Note: only has just been run in, needs to go back to get bugs ironed out like cold start,and leaking injectors. Leaking exhaust manifold.
    1992 Toyota Hilux Extracab
    2JZGTE - TO4Z powered.
    1968 Toyota Stout Lite
    Work in progress
    SO00RA Domestic Engineer 4agerolla's Avatar
    1JZGTE VVTi
    Stock
    Stock
    Forced induction:
    Stock single turbo (CT15B), 11psi
    Management:
    Stock
    Fuel used
    BP Ultimate 98
    Intake:
    BFI (Modified stock airbox) with K&N panel filter
    Exhaust:
    3" turbo back, high-flow cat, splitting to twin 3"
    Driveline:
    Stock R154 + LSD
    - Silver 2012 Lexus ISF - 2UR-GSE 5 litre V8 goodness
    - Black JZZ30 Soarer - 1JZ-GTE VVTi + factory R154 manual
    - Blue KE17 Sprinter- 3k + K40 manual
    - White MS55 Crown - 2M + 4 speed column shift manual
    - Blue MS51 Crown Hard Top - Angry 4M-B + W50 manual
    Feb 2008
    2jz-gte
    none
    none
    Forced induction:
    Stock twin CT20A turbos, stock boost
    Management:
    nil
    Fuel used:
    98ron BP
    Intake:
    stock
    Exhaust:
    3" catback
    Driveline:stock
    312rwhp (will post soon)
    1JZGTE non vvti '91
    Stock
    Stock
    Forced induction:
    Stock twin turbo, 18-20psi (hks evc3 turned off)
    Management:
    Stock + greddy FCD
    Fuel used
    BP Ultimate 98
    Intake:
    K&N pod filter in aluminium airbox
    Exhaust:
    2.5in custom dumps into 3.5in which gradually tappers down into 3in + single magnaflow race series 3in muffler. - no cat
    Driveline:
    Stock R154
    jay zee zee thir tee Carport Converter HAVABEER's Avatar
    engine:
    1jz-gte (non vvti)
    Stock
    Stock
    Forced induction:
    Stock twin turbo, (stock boost pressure)
    Management:
    Stock
    Fuel used
    98 ron
    Intake:
    stock
    Exhaust:
    stock + 2 small cannons
    Driveline:
    Stock
    an absolutely bog stock 1jz soarer thats done 96,000k's
  1. sticky dyno results thread
    By chris davey in forum Toymods Car Club Membership and Feedback
    Last Post: 20-06-2007, 07:07 PM
  2. Toymods Dyno Day 13 - Sunday, July 2nd
    Last Post: 21-07-2006, 01:32 PM
  3. Dyno Day 12 - Final Results!
    Last Post: 24-02-2006, 12:12 AM
  4. Dyno Day 12 - results thus far...
    Last Post: 28-01-2006, 01:35 PM
  5. Dyno Day 12 - Sunday January 15th 2006
    Last Post: 25-01-2006, 11:46 PM
