While the Gen 1 flywheel is the right dimensions for your project, as you've discovered the PCD of the bolts is slightly different.
BTW, the PCD of all Gen 2 onwards 3SG flywheel bolts is the same, its only the Gen 1 thats different.
I ended up getting a custom made flywheel and using the ring gear off a RA40 on it. I would imagine a 2S ring gear would be fine too. You can get these off the old flywheels with some heat and careful hammer use or buy a new one but they're $$$$.
If you're designing a flywheel you can largely use anything that had a W5X gearbox as a guide. The PCD is different (obviously) and you need to check the distance the throw out bearnig has to travel.
I think an Altezza flywheel may also suit (don't have it in front of me to measure so can't be 100% sure) but they're probably too heavy for a competition car anyway.
Couple of things to be careful of.
You need to put a spigot bearing in the end of the crankshaft. If you use a standard width one, the input shaft of the gearbox doesn't locate in the spigot bearing properly. You need to machine 5mm of the mating face of the bellhousing.
The alternative is to use a dual row bearing, or to machine the flywheel so the spigot bearing locates in that.
I you're interested I have a low inertia racing flywheel that takes a 5.5 inch racing clutch. Its small diameter so I was planning to attach a auto drive plate / ring gear to it to allow the starter to work.
PM me if this is of any interest to you.
