The 18R and 18R-G vacuum advance mechanisms are different in vacuum resolution and also fitting depending on which model 18Rg dizzy you have.
We have an 88230 dizzy here that uses a vacuum advance that has too small a diameter where it mounts into the dizzy casing for later model one to fit. You'd have to modify either the housing or the vacuum advance. (the casing on this one uses an RT-40 dizzy cap and the casting is similar to that model dizzy in other respects and also internally.
Later models (88251, 88270) use a more regular sized advance unit (the models that are suited to the 22R electronic conversion).
The 88230 one that we have acts from 0mm/hg upwards with the action levelling off at about 150mm/hg.
The 18R one starts acting at about 150mm/hg and levels off at about 330mm/hg.
I do original 88251 and 88270 ones that I could measure up to see where they work. I would have to find them though, which is not such an easy task these days, we put everything into boxes and stacked them...bad move.
Hopfully this helps, but if you really want the specs of the later model ones. let me know and I'll tack it down for you.
