EPC says
ST141, RT142, SA63, RA6# are the same.
I'd still check this first hand but that is what the EPC says
I need to replace my steering rack, what I need to know is, does it have to be from an ra65, or can I get one from a powersteering ra60/sa63. Or are there any other cars that have the same steering rack? Also what price would I be looking at for a second hand one?
Sa22c Series 1 rx7, 12a extend port, 900rwkw @ 93,320 rpm sold
Ra65 celica hatch, 22re with 2.25" exhaust, 500Nm @ 27rpm sold
Ae86, 4agze, 170Takumi Powers @ 11,000 rpm
EPC says
as if a6's need p/s!...wouldn't mind one in my car sometimes...would make the bigger tracks a bit easier to drift
Toyota Celica JZA65 Drift Car
KAIZEN GARAGE - QLD agent for Adaptronic ECU
spaRk secRet - HID headlamps
If you don't appreciate power steering, then you're not running enough castor.Originally Posted by timottaway
I've had issues with swapping an RA60 rack before, I remember there being differences and having to try a couple before I found one that fitted. Sorry, I can't remember exactly what the issues were though.
MA61 isn't the same as SA63 etc that I can say!
But yeah i'd still check to make sure!
I like that, sounds good.Originally Posted by mrshin
Originally Posted by skiddz
yeah i've run 4.75 degrees and that was with a locker....far too heavy
nothing more than 4 is required for a celica this together with p/s far too light....
its a good setting to stop excessive dyanmic camber once a bit of lock is dialled in..
from experience in a track environment, p/s failures etc fair outweigh there advantages. non p/s rack with p/s arms give a quicker rack and more direct steering feeling and a better feeling of castor and steering angle.
i'm extremely bias i'm quite the non p/s diehard!
