Results 1 to 13 of 13
Thread: 1jz into MZ21 wiring help please!!!
    Apr 2007
    Alberta
    Question 1jz into MZ21 wiring help please!!!
    Hey every body, I'm a new member looking for some info. Trying to swap 1jz into MZ21 7mgte and don't have a clue about the wiring by the computer or under hood! I see that a few guys here have done it so I hope you can help. Thanks
    You broke your what?!
    Default Re: 1jz into MZ21 wiring help please!!!
    going to need to be more specific. Where are you up to and what are you having issues with?
    QUICKEST 1JZ'S IN OZ
    Have you looked through all the threads, like : http://www.toymods.net/forums/showth...light=1jz+mz20
    There is A LOT already covered on how to put a JZ-GTE in a a MA61 through to MZ20 (21).
    Apr 2007
    Alberta
    Hi guys, I think I might pull out my hair!!!
    Apr 2007
    Alberta
    Hey guys I looked through the threads but all I need is which wires to connect to make it run. I am doing this for a buddy and I am in Canada. I can make it turn over but not start. I figured out the starter wires but no fuel or spark. The car was mz21 7mgte auto put in jza70 1jz auto. Can't get any wiring diagrams where i am at and nobody has these cars here. Can't here fuel pump with key but when i put power to the pump manually it turns on. I just need to get the car to start and run, the other stuff like gauges and a/c and speedo/tach don't matter to him right now. All I need is the Soarer wiring colors and where they connect to. Wish I lived there - hot weather, hot cars' hot women. Thanks guys.
    Western Aus
    supra/soarer/cressida wiring is all relatively similar.
    theres a connector just behind the fusebox on the 1J, its called the "EA2" connector, that needs to be connected, along with 4-5 wires behind the glove box
    the EA2 connector runs your ignitor, alternator, and the temp sender in the bottom of the radiator.
    the wires behind your glove box give power to your injectors (and ignitor as well i think?) make your car crank, and give power to your fuel pump.
    basically, to run the car you need the big square plug behind the glove box with the 2-3 big fat wires in the middle of it, and the EA2 connector in the engine bay.
    Elmo.
    Apr 2007
    Alberta
    Hey Elmo, I have hooked up three wires behind the glove box. I think they were blk/org, blk/wht and blk/blue. Are these correct? As for the EA2 connector I hooked up blk/org to blk/org, blk/red to blk/red and blk/yel to blk/yel from EA2 to small 6 pin connector. I don't know if that is correct. still no start.
    Apr 2007
    Alberta
    I forgot to mention we are using aftermarket electric fans.
    makes me laugh tryin to wire stuff that takes ages to do properly over the net
    if u actually had a brain u would sit down study the whole wiring it might take u 2 days but
    much quicker than tryin to wire up one wire at a time on here
    most jobs where the owner trys to wire up shit by asking thru the internet one wire at a
    time the job usually turns out to be one bigggg bag of speghetti
    trust me ive seen it many mnay times
    asking what a wire does without researching where it goes is how u fuk things up
    anyway ill come back in a month and see how its travelling
    Apr 2007
    Alberta
    Thanks for the confident reply sideshow. It was my first large wiring conversion, freaked me out. Got it all figured out yesterday. Sat down for 8 hours with my diagrams and my soldering iron. Runs great! Only problem is it is an auto. Thanks for all the help!!!!!
    Western Aus
    not all of us are are forward as sideshow, we do actually like to help.
    glad ya got it sorted, his post obviously worked its magic
    Elmo.
    this is why i stay away these days
    doin this is how i make money to make a living
    i help but to a certain amount
    nothing is free these days and getting things done by a pro costs money
    anyway i dont care about shits like this anymore
    i just hopped back on to say that knowledge is worth alot
    maybe if u had a skill you would charge people for yr work aswell
    what do u do for work
    maybe u can throw me a freebie and i will throw u one
    anyway its people like you that made me and many others leave
    so cyaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    Western Aus
    ok, when what you just said makes sense, ill let ya know.
    all in all, i think your cocky.
    sure you know more than most about wiring, but obviously not the be-all end-all of wiring problems, since bhe got it sorted and all!
    Elmo.
  1. wiring microtech to tacho 1jz
    Last Post: 29-06-2011, 01:04 PM
  2. MX83 1JZ wiring
    By matt100kw in forum Engine & Driveline Conversions
    Last Post: 08-04-2007, 06:20 PM
  3. 1JZ Wiring into a BMW E30 in Sydney
    By LoCo in forum Tech and Conversions
    Last Post: 01-02-2007, 10:01 AM
  4. 1JZ A/C wiring help
    By rogue-vl in forum Tech and Conversions
    Last Post: 16-09-2006, 03:04 PM
  5. Microleb wiring assistance on 1JZ!!!11oneone!!11(LTX-12)
    Last Post: 23-05-2006, 12:27 PM
