Results 1 to 13 of 13
Thread: Supercharger on a 3rz Engine??
    Aug 2006
    Default Supercharger on a 3rz Engine??
    hi guys
    Any recommendations on putting a supercharger onto a 3rz engine?? Power gains??
    Recommendatons on best option(s)
    Pros cos etc etc??!!
    cheers in advance!!
    m
    Default Re: Supercharger on a 3rz Engine??
    I recommend supercharging your 3RZ.
    There will be power gains.
    Your questions may be a little vague.
    Aug 2006
    Ahh ok
    Wnat to know what power gains there would be???
    Also..
    whats a good one to put on??
    Any reliabilty issues??
    That sort of thing!!
    I think you're approaching this in a backwards fashion. You should be asking a question like this:
    "I want to increase the power output of my 3RZ to xxx HP, what's the best way to acheive this?"
    You start with the problem, not with the solution! A supercharger may be the best way to go or it may not. So, tell us about your goals, your budget, your mechanical abilities, etc and you may get some meaningful answers.
    Aug 2006
    Nar mate not at all.....
    What im trying to do is get an undertanding of what gains i will get out of it. I know nothing about super charges and not that much about the 3rz either. But i have read some gr8 stuff. I wanna know how it will perform and what i will notice. U know what experiences evryone else has had et etc etc.
    Im not after any magical figure but i do get tired of a stock cars power. I currently drive an RS turbo so going into the hilux will be a big difference.
    Some meaningful ansers may be.... If you bolt on a (A654 example) supercharger on to a 3rz you will get this this and this happening.
    I dont have much of amechanical aptitude so I will be gettting others to do the work..
    Is that enough????
    I'm pretty sure capa do a bolt on kit. If not a mob called alpine developments definitely do a kit that got sold in america through trd outlets.
    Aug 2006
    cpa do yes hefty but!!
    Powerdyne, Landcruiser 4.5L Petrol 80 & 100 series
    Inc
    1
    6.5
    220/245 ex
    $ 6,319.00
    Vortech, V-2 Quiet, Landcruiser 4.5L Petrol 80 & 100 series
    Inc
    2
    7.5
    225/270 ex
    $ 7,498.00
    Landcruiser 4.5L Intercooler Kit
    Air/Water
    Add 30kw
    $ 2,675.00
    Intercooler Boost Upgrade, Fuel Pump, Pulley Kit, 8-Rib $ 400.00
    Eaton, Toyota Landcruiser 4.5L
    Inc.
    3
    5
    215
    $ 7,998.00
    Vortech, V-2 Quiet, Landcruiser 4.7L
    Inc.
    1
    7
    $ 7,495.00
    Toyota Prado 3.4L V6 Eaton
    option
    1
    6
    195 ex
    $ 6,990.00
    Toyota Prado & Hilux 4.0L V6, 1GR-FE
    Vortech V-2 Quiet option 1 7 280 ex $ 9,995.00
    Toyota Hilux 2.7L Petrol Eaton
    option
    1
    7
    140 ex
    $ 6,290.00
    oregon
    wa
    mgfe
    empty your pm box it is full
    Aug 2006
    done sorry
    theres several threads on this forum about forced induction and the 3rz engine, theres atleast 2 turbo ones on here me being one richard being the other. ill find the thread where someone asked the same question im not typing for 6 years . edit: couldnt find it
    ill make it simple, sell the rs liberty to your grandma cause a boosted lux will destroy it
    the 3rz is capable of over 300rwhp without throwing a rod out the block after 2 weeks, and without opening the engine for anything including headwork or headgasket upgrades or lowering the compression in anyway....
    you could expect to make 200 - 350+rwhp if you TURBO it with an aftermarket ecu, exhaust , fmic , gt35r etc turbo , fuel system upgrades ( im running 12psi through a to4 now and the injectors are pushing on 90% on full boost with a lifted fuel pressure., and the obvious turbo manifold, lines and a new clutch and possibly a new gearbox if you go pushing it to higher power levels and flog the shit out of it all the time (my box is doing fine so far but has only been on the road properly for 2 or 3 weeks now. richards utes thread is a good info gatherer for you to see whats involved mine has pics to have a look at probly has a half arse price list in there too.
    if you run the supercharger the stock ecu seems to go ok at keeping it together and not running it stupidly rich or stupidly lean with a rising rate fpr, run a turbo and the ecu WILL NOT run it properly, stalls at lights and carries on like a school girl. so a sc14 or similar you can save the price of an ecu and tuning and wiring if you can do it your self.
    but after that long winded story, i think a turbo is better rather then just thinking about the blower, the blower has been done by a mate of mine with a sc14 and the power output is very average compared to my turbocharged one with similar boosts between the 2, but at the end of the day it depends what your after, how much power you want to make and how much money you want/can spend. if you want just a bit more torque and power run with a sc14 blower , a como blower would probly be ok and would make more power...
    if you decide to go ahead with forced induction this info will help
    heres a walkthrough of mods,wiring,maps etc but this is only for turboing it
    http://www.toymods.net/forums/showthread.php?t=12647
    ive got haltech maps for the 3rz if you ever decide to put some boost in and a haltech. other than this forum and the few scattered 3rz threads on this site there is virtually no info on the web worldwide.
    gtt30r turbo or to4 is a bare minimum for the engine i had a r33 turbo on to begin with and the 3rz is constantly ringing its neck.
    wa
    nice info berad after seeing your dyno graphs it makes me want to keep the 3rz but i think the limited info on it will keep me from doing it. so i will be one of the sheep
    ps mgfe your pm box is full again
    ecotechilux, what do you need info for? theres enough out there to show you they can make over 350rwhp unopened, and lc engineering in the states can get you every single forged or aftermarket part for them to rebuild.... theres wiring diagrams , ecu maps , etc etc
    harden the fuck up
  1. Toyota R Engine History
  2. 5M E to 5M GE/6M GE Conversion Guide
    By spiller in forum Engine & Driveline Conversions
    Last Post: 29-11-2011, 01:03 PM
  3. MA70 --> JZA70 Conversion
  4. engine ideas
    By Blade20034 in forum Tech and Conversions
    Last Post: 17-10-2006, 08:23 AM
