sean do you know if 2J studs are the same as 1J?Originally Posted by MS-75
I've just fitted my 4.5L PETROL Landcruiser motor with a set of 2JZ head studs. They are a straight drop-in.
Awesome.
Project Soarer II - Sold
Evo 5 - The silver fruitbox
Not sure dude, but if you can give me a 1JZ head bolt and a couple of measurements I can tell you.Originally Posted by MR 1JZ
i would love too...except mine are in my motor
I'd say they probably are. Drop past my place sometime and I'l have a look if you like. I should be able to work it out.
Actually, I'll have a mate measure up the bolts on his 1J and get back to you.
awesome cheers!
+ 1 rep for you
also i might take you up on the offer of a drop by as I wanna check out this super crown in the flesh...
This is getting off topic, but doesnt Kirby have the bolts out of his 1J?
BTW, I commented earlier in this thread that SV21 camry front axle assemblies might work on an AW11 MR2 rear.
I recently acquired one, and no, it wont. Simple reason being the hole for the steering arm is tapered in reverse to the MR2's. MR2 steering arms bolt in from below, SV21's from above. Aside from that, it still looks damn identical.
i was there on sunday and it looked like the head was intact :SOriginally Posted by takai
An amendment
St205 rear brake assembly DOES bolt up to an St185 - though - as discovered today - there is issues with the handbrake cable .. Am in the process if working out how to rectify this - as its got to so with the small clamps that hold the cable to stop it flexing ..
Small issue re making the rear shoes come out a little - addes bonus squeak squeak atm in the back end as its rubbing a little inside the brake shoe
Saphira - ST205 Celica GT-FOUR Group A NZ No:1/4"Mongrel Garage - back on Aussie soil! "
TRX Blue Bird disc Brakes fit T series diffs with little mods.
RT104 Corona manual tail shafts fit RA23/28.
Ms85 crown rear vision mirror with night view fits RT104 Coronas.
BMW M3 pressures plates fit 18r flywheels all you need to do is redrill the mounting bolt holes and dowel holes.
Ms85 crown glove box lights fit Rt104 Coronas
Any more info on this, ie. Does it only apply to disc brake t series diffs, or drum brake diffs as well. As well as this what calipers can be used and what is required to get it all together.Originally Posted by ra_28
Sorry the TRX blue bird disc all that need to be done is go to the wrecker and get the hole setup off the end of the axles including calipers and hand brake cables.
To mount the rotors the four bolt holes which mount to the end of the axle housing have to be slotted in about 3mm not much and bobs your uncle there on there the brake line has to rebent a little not much.
The setup of the hand brake cables is a little bit more tricky I wish i still was running the setup I would have taken some photos just use the whole cable becasue the cable I got had the same setup as a ra28 where you adjust the cable from the inside the cabin so it was just how you supported the cable under the car. I made a few Brackets up and it worked ok.
The size of the rear rotors and calipers is quite large so if your fitting larger barkes to the front the bias workes out very well.
I know this will work on ra23/28 and RT104 coronas pre bog warner because these are the cars I have played with.
Ok, that sounds sick, thanks for that, I'll give it a shot on my TA22, ill see what i can screw around with down at the wreckers before i go for anything solid. This is from a 81-86 Bluebird correct or the 93-97 model and is it only the TRX model?
Btw Rep for you.
I got mine off the 81-86 model
