My setup consists of the following (running standard smallport 4AGE)
Standard unmodified carby fuel tank
Inline "VL" type fuel pump mounted on one of the fuel tank straps, don't know what brand it is exactly.
To a point, the fuel pressure is controlled by the fuel lines and fuel pressure regulator. Pumps don't
"make pressure" they "supply" it depending on system restriction. Mine seems to work fine, basically
run a pump rated at the same pressure as standard if you can, as you don’t need any more. If you can
only get a pump with a higher rating, don't worry too much about it.
I'm using the standard lines and it works fine, I have heard of people using standard lines on 4AGZEs.
If I was going to replace anything, I would fit a new 8mm delivery line, and use the old 6mm delivery line
as the return line.
Make sure you change all or the rubber hose to high pressure EFI hose, and use the proper hose clamps
(I'll post a pic of these when I get home)
You will need some reducers too, a 12-8mm (or similar) for the fuel tank to fuel pump a 8-6mm for the fuel
pump to the fuel line (or wimilar) , two 8-6mm for the fuel filter in the engine bay, a 6-4 for the return line
and a 6-8 for the fuel rail supply fitting. A decent pirtek should be able to get all of this for you.
I higly recommend using a surge tank, as I get fuel surge when I have less than a third of a tank on the
Street, and its worse on the track. I'll post a picture of a swirl pot/surge tank design and the way you
should hook up the lines.
I'm looking in to what pumps to use myself, so I will post up what I end up using.
