Results 1 to 6 of 6
Thread: 2ZZ help
    Is a Self Employed Grease Monkey wombat's Avatar
    Arrow 2ZZ help
    Hi all I'm starting to look into the 2ZZ engine as a project I want to get as much info as possible.
    So any info or links you have please let me know, all info is appreciated.
    I am really interested in a RWD conversion for this engine so anyone who has info on this or knows of someone who has this info please let me know.
    So I'm in planning for a 2zz, so I want the info before anything goes ahead.
    So please help.
    Thanks
    no backyard Domestic Engineer japlish's Avatar
    Default Re: 2ZZ help
    i had looked into this breifly and actually bought a stuffed 2zzge motor as an experiment.
    i didn't get to far but i found a couple of things.
    1.There is no provision on the exhaust? side of the block for a engine mount, i did have thoughts of making some sort of cradle for it but like i said i didn't get that far.
    2.you'll have to get a remote oil filter setup because the oil filter points straight down and would foul on a rwd crossmember.
    3.the input spline is the same as a ae86 t50 gearbox which means you may be able to use a factory 2zz clutch if you use a t50 gearbox.
    4.the usual cut and shut inlet manifold jobbie
    5.no distributor so thats atleast 1 good thing!
    6.it has a 'front sump'
    I remember someone in the US doing this but can't remember the link, sorry.
    A very good technical document on the 2ZZ here ->
    http://www.mmsport.com.au/download.php?fid=34
    www.billzilla.org
    Toymods founding member #3
    Locust forums - dude there RWD converted one with W55 box and adaptor ring. Was a member here - might have been old forums though.
    Here it is:
    http://forums.toymods.org.au/index.p...25f84e66cdb696
    Japlish:
    Thanks some good info there and some notes to keep in mind.
    Billzilla:
    Thanks for the link. I had that document already. plus the I have one I got from a lotus elise website. just a comparison between the elise version and the celica version.
    Gianttomato:
    That link is great. I'll look at the pics when I'm not at work cos stupid GM won't load the link aparantly it has something to do with P*rn. who knows.
    Keep the info coming. anything I get myself I will put on here for you all to see.
    Bumpity bump bump
