Page 1 of 3 123 LastLast
Results 1 to 15 of 31
Thread: KE35 Corolla Conversion 1GGTE or 4AGTE?
    Junior Member Grease Monkey Brad-KE35's Avatar
    Default KE35 Corolla Conversion 1GGTE or 4AGTE?
    G'day all,
    I've been planning a 1G conversion in my car for quite some time now, I have Hilux diff, hydro clutch etc, and am keen to do a engine conversion, now I had my sights set on a 1G after being in my brothers 1G corolla he bought off Josh. But in terms of fitting the motor with ease the 1G looks like a really tight fit, and boy does it get hot under the engine bay of a 1G corolla! So what do you all reckon I should go? 1G or 4A? I am at least after 200+ kw. How hard would this be to achieve in a 4A?
    Any thoughts or questions would be appreciated.
    Brad
    1977 Toyota Corolla KE35 - Undergoing 4AGTE transplant.
    1994 Ford Falcon Pedovan - Rape Dungeon
    Montrose
    Default Re: KE35 Corolla Conversion 1GGTE or 4AGTE?
    1 vote 4AG.
    And what are your reasonings Shin?
    Junior Member Domestic Engineer NeoNasty's Avatar
    Vote 1 1G.
    Already turbo. 2 liter 6 cylinder. Less fab work required, able to use the standard ECU.
    Why do you want 200kW? Thats a lot for a little Ke35. You'll need good brakes, and suspension if your to use all that power.
    *vote 1jz.
    HZJ75, RS41, JZZ30
    I vote 4A. Its taken you 8 years just to make the mounts for that, so changing to a 1G will just set progress back by another 15
    Yeha I dunno why I picked 200Kw, just a number I had in my head, and don't worry I have brakes and suspension sorted! Thanks for your opinions Neo!
    And Bananaman, what are you talking about lol? I'm confused!
    ethanol sniffing Backyard Mechanic adamaw11's Avatar
    Is it still gonna be a daily?
    I vote 4A
    still only 4 cyl rego
    light enough car that lag shouldn't be that much of a problem if you want 200rwkw.
    shouldn't upset the balance of the car front-end-weight wise.
    Start with a 4agze so you don't have to go strenthening internals.
    To be different, consider 3RZFE
    -already a north-south engine
    -still only 4 cyls
    -2.7Ls to play with.
    NA: [email protected] at willowbank. On E85 with 6psi boost: [email protected] ~8psi: 13.187 @169.9kmh. >10psi: 12.9 rod fragments @ 174mm holes in block
    daily: '93 ae101 Levin coupe. Motorbike: '09 Suzuki GSR600: [email protected] at Willowbank
    is the 3rz legal?
    I have the 4agte. Its a decent power maker without filling the whole bay up and being a PIA to work on the engine with it still in the bay.
    You want a stack of power and want a FMIC sticking out there? Plenty of fabrication but atleast a w5* will bolt up, then go the 1GGTE.
    Ah thanks guys! You have a W5x in your KE30 Cuzzo?
    Cheers guys,
    Brad
    yeah i do.
    needed a nitespart bellhousing. exy but worth it.
    Ah cool! Thanks man!
    My Missus is a Domestic Engineer BradW's Avatar
    Quote Originally Posted by Brad-KE35
    Hey Mr Bananaman, are you thinking of the wrong Brad?
    Another vote for 4ag here.
    Brad
    Old Corollas never die...
    My KE30
    i vote the 3rzfe, i regret not doing it in my ra23 and i have a 1g
    Yeah they seem like a good strong motor to turbo, have to look further down that path.
    Thanks guys.
    Junior Member Domestic Engineer dfunkt's Avatar
    Apr 2007
    curly/rod has put a 3rz turbo into a ke38 wagon quite recently. pretty sure there's a thread in the members rides
    http://www.toymods.net/forums/showth...highlight=ke38
    Owner of the Big Red Whale
    "i cant eat this because its too spicy" "i cant eat that because it has green stuff in it" "i cant eat that because its chilli soup with Blair's Ultra Death Sauce in it"... winge winge winge...
  1. MA70 --> JZA70 Conversion
  2. (TA22) 2T - 2TGEU conversion (now with pics)
    Last Post: 13-11-2006, 09:52 AM
  3. Getting 4agte conversion done... where in perth shall I go?
    By AE101LEV in forum Tech and Conversions
    Last Post: 25-05-2006, 08:59 PM
