Results 1 to 4 of 4
Thread: coilover sleeve lenght?
    south australia
    Default coilover sleeve lenght?
    hey peoples.
    quick question, how long are your threaded sleeves for coilover kits?
    i have just been viewing the other threads about the coilover conversions and i measured my sleeve out of curiosity and its only 120mm long.
    Im planning on using SW20 MR2 KYB shocks. When i shorten the strut, where should i have the sleeve welded on. ie how far from the top of the strut??? so that i still get best use of the shocker.....
    Huw
    Oh What a Feeling! Backyard Mechanic c2888's Avatar
    Default Re: coilover sleeve lenght?
    Depends on your spring length. Obviously longer is better because then you have enough thread if you get longer springs. I've built some with a 10 inch spring and I think that a shorter spring with a shorter thread mounted higher up would have been better.
    WHY: you lose a bit of wheel to strut clearance when you have the threads really low. Ideally you would only have a few cms of adjustment for corner weighting and adjust height via different lenght springs. But everyone wants to have the easy undefect up we go long threads.
    dan
    south australia
    well. the springs i have are only 6.5 inches long with no weight on them.
    there is a helper spring on top tho, to keep the spring captive. the total length is 10 inches
    Who da F%^k is Takumi?? Backyard Mechanic 45aken's Avatar
    my sleeve is 120mm long, and sits about 20mm from the top of the 50mm shortened strut. plenty of adjustment.
    AE86 - coming soon to a quiet mountain pass near you...
    WRX - currently epa'd...
  1. Guide: Coilover Conversion
    Last Post: 18-03-2007, 09:45 AM
  2. Tailshaft lenght with a W5# gearbox in a ae86
    By Cameron_Datto in forum Tech and Conversions
    Last Post: 14-01-2006, 06:29 PM
  3. coilover tube thread Q
    Last Post: 13-01-2006, 07:38 AM
  4. Coilover question re: upper hat
    By xolent in forum Tech and Conversions
    Last Post: 26-12-2005, 05:12 AM
