4AGE 20V -> Aftermarket coil
Hi all,
I'm considering sticking an aftermarket coil such as a MSD Blaster onto my 20V.
Main problem is the plugs on the coil/dizzy lead... the 20V dizzy has a pin/clip type connector, as does the 20V coil. However 90% of aftermarket coils are the typical post setup.
Does anyone make a coil lead with the Toyota clip-on on one end, and the "aftermarket" type on the other end?
Spectral.
Re: 4AGE 20V -> Aftermarket coil
You can get a coil lead made up pretty cheaply with the right connectors on each end. There's a place in Slacks Creek that does them on the spot, I'll see if I can find the company name.
whats wrong with factory coil
never had any probs with them
even when turboing the 20v they still work well
Thanks JP, that would be appreciated.
Sideshow: The coil has some large question marks over its health. I can get the MSD Coil for about $70, and a new Toyota one is about double that (or $50 second hand).
If a cheap lead/convertor was available, then the MSD coil makes sense, IMO.. may as well upgrade.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
