Results 16 to 30 of 41
Thread: Toyota Manual Gearboxes and their Ratios (W, R, V, K, T, P)
    User Conversion King
    NWA
    Default Re: Toyota Manual Gearboxes and their Ratios (W, R, V, K, T, P)
    nup,
    no mention of S series in either sites
    hello
    couple this with all possible diff ratios and we might be onto something... make a speed calculator.
    NWA
    im sure norbie could integrate it into his toyota diff database.
    need to know;
    -max engine rpm
    -gearbox
    -diff ratio
    - wheel size/rolling diameter
    hello
    Quote Originally Posted by ViPeR_NiPPleX
    Yep norbies new thing has this already....(not released to the general public yet!)
    It can make speeds in gear graphs for different boxes / wheel / diff combos
    *waits for someone to post link...*
    Plenty of speed calculators around, i have not used a net one for years but ill look!
    NWA
    Quote Originally Posted by kingmick
    Took all of 30 seconds to find the first one!
    http://www.scirocco.org/gears/
    WTF has "VW Gear Ratios " got to do with making a program to select toyota components.
    the maths is so simple its not funny, im sure even you could do it mick
    but having drop down menus to select diff ie F292, then another drop down menu for gearbox, ie W58 and then graph them all is another thing.
    that speed calculator you posted only works with one gear
    hello
    The calculator is the useful bit for people i thought! as i said i have not used one on the net for years, as i use Hewland one for gearsets.
    You mean to choose diff ratios to suit what they want? not much component choosing as there are only a few gearboxes one would use??
    NWA
    the aim is to produce something like this.
    hello
    My tool does all of the above, including the pretty graph.
    Note: still in beta. Also I've developed a new feature which calculates the correct speedo drive gears required for any wheel/gearing combination, but I haven't pushed it up to my web site yet.
    http://akb.norbie.net/Public/Gearing.aspx
    Thats pretty, be some thing new to me as everything is normally calculators not graphs!
    Very pretty.
    NWA
    the graph tells you a 1000 things a calculator cant.
    i would have thought someone on a race team like you would have used them religiously.
    you can go further and line in each gear to see whether the gears keep the engine in the powerband
    hello
    Use a combo for that!
    I will copy a couple of pages of the Dallara F3 book, its the best one ive seen and would be nice in software format.
    useful to have the gear ratios in the one thread so searching finds them as well as Norbie's database.
    "motoring enthusiast" Backyard Mechanic mideon_696's Avatar
    what about c52?
    No Signature.
