Results 1 to 2 of 2
Thread: does 20 valve gearbox handle 4agze
    Junior Member Backyard Mechanic KARNAGE's Avatar
    Default does 20 valve gearbox handle 4agze
    Hi everyone i used to have a 20valve blacktop but ended up spinning a main bearing actually a few so i have decided with going with a 4agze as a starting block. I have a few questions?
    1. As i have a 4agze engine and gearbox but no drive shafts to suit will the old 20 valve box be able to handle the job as i already have the drive shafts to suit.
    2. I had a link plus running the old engine set up with a map sensor arrangement that should be fine to use with the new 4agze set up or not?
    Any help would be greatly appreciated
    T'ville, QLD
    Default Re: does 20 valve gearbox handle 4agze
    mmmk answers to your questions
    1. the 20v box will be fine
    2. is the link ecu set up for 20v? or is it like an adaptronic that can be programed? if yes to the first, nope get another one, but otherwise if ya can reprogram it then should be ok
    now, some points of my own
    1 wrong section
    2 search
    that will be all, your lucky im in a good mood so no neg rep will follow but search first ask questions later
    2T out 4A in....
  1. T, 2T, 2T-B, 2T-C & 2T-G Specifications & Diagrams
    Last Post: 29-02-2016, 12:30 PM
  2. Verifying a w58 gearbox
    Last Post: 09-10-2008, 11:39 PM
