Results 1 to 4 of 4
Thread: 4agze afm+cas w/ std ECU turbo conversion, anyone done it?
    Jan 2007
    Default 4agze afm+cas w/ std ECU turbo conversion, anyone done it?
    As the title states, has anyone converted a series II 4agze w/ afm+cas and std ecu to a turbo setup succesfully?
    south australia
    Default Re: 4agze afm+cas w/ std ECU turbo conversion, anyone done it?
    yeah it has been done before, have a search round. im sure you will find some info.
    there is a limit to how much the standard setup can do tho. i wouldnt be running much more than 12psi on this setup.....that will give you a bit of a safety margin
    but i think a MAP version of the engine would work better than the AFM version tho
    If your nice maybe YLD-16L (the old KE382TG) may give you tips. He ran a KE38 with a AFM/DLI OEM ECU 4AGTE with nothing more than a FPR. It pulled 154RWKW if my memory serves me correctly.
    It used a RWD intake manifold, T28 and custom turbo manifold and IC.
    Denis
    Oh What a Feeling! Backyard Mechanic c2888's Avatar
    http://forums.toymods.org.au/index.php?t=msg&th=45441
    Monkeymajiks car is one of the other cars i remember running ae92 electrics on their turbo 4agze conversion.
    Also have a sniff around the toyspeed.org.nz for a few turbo setups using factory electrics.
    Dan
  1. Travs 3SGE +turbo RWD conversion
    By TRAV-KE55 in forum Tech and Conversions
    Last Post: 08-09-2010, 07:50 AM
  2. Comp ratios of the 4agze dli with AFM?
    By dug in forum Tech and Conversions
    Last Post: 22-04-2006, 07:15 AM
  3. 4agze aftermaket ECU, worth it?
    By rollamattae86 in forum Tech and Conversions
    Last Post: 07-04-2006, 10:02 AM
