no the heads are the same, dont no bout intake and zorst id say it would be pretty similar, for upgrades id say look at the turbo and perhaps freshen it up, then u can look at more boost, the motor will run 6 psi stock and the ecu will let u make 15 psi before it cuts u, it has the WTA cooler on it which is pretty good but upgrades would also be a FMIC and a bigger dump pipe of turbo prob 3 inch, i would also recomend changinf the headgasket perhaps putting a stronger one on it before u run into any troubles, say a stainless steel one, wat are your plans for the engine ?
