Page 12 of 12 FirstFirst ... 2101112
Results 166 to 167 of 167
Thread: 2jz into hilux
  1. #166
    wa
    Default Re: 2jz into hilux
    I have changed my diff ratio to 3.9 but im not sure what to do about the gearbox now was going to keep the toyota auto but im thinking about going a 2 speed powerglide or turbo 400 not sure yet. anyway this is as far as i have got so far
  2. #167
    Plenty of tough MV built toyota boxes behind it, and if you want to actually drive it around town (especially if you put a larger stall in it) you are going to want 4 cogs and a lock-up clutch..
    i doubt you will be able to put enough torque to the ground to break a toyota box anyway
    you will probably want a late-model (around an AU?) windsor (ford v8) tensioner pulley if you are going to run the belt around the outside.
  1. late 97 on hilux 3rz turbo conversion walk through
    By BeRad in forum Engine & Driveline Conversions
    Last Post: 07-01-2011, 08:10 AM
  2. Rn110 hilux 1GGZE conversion
    By Bullfrog in forum Engine & Driveline Conversions
    Last Post: 15-02-2009, 09:17 PM
  3. 1GGTE to Hilux conversion help
    By nedm in forum Tech and Conversions
    Last Post: 12-10-2007, 04:39 PM
  4. Flywheel for 1G-GZE Conversion into Hilux
    By infotechplus in forum Tech and Conversions
    Last Post: 16-11-2006, 06:41 AM
  5. YN57 hilux power steer conversion - how to?
    By Robbos_Toyotas in forum Tech and Conversions
    Last Post: 13-11-2006, 12:15 PM
